cheap desktop for t...
[Closed] cheap desktop for turbo training....this ok?
I'm after a PC to use with Bigring VR and also Zwift at some point.
Looking at this
https://itzoo.co.uk/collections/pc-base-units/products/refurbished-hp-elite-8200-tower-pc-core-i5-2400-3-10ghz-4gb-windows-11.
£103.50 with new customer discount code.
I'm planning on just hooking it striaght up to the TV so not using a monitor, but i should be able to connect to the tv HDMI from the computer display port?
Would i be able to stick a reasonable graphics card (eg GTX 1050)  in it at somepoint for zwift?
Also i see on amazon theres a few different manufacturers making Nvidia 1050 cards, are they all pretty much the same?
thanks
Posted : 23/02/2018 4:19 pm
Looks good, but if you had a few quid spare I'd go 8Gb (get an extra 4 aftermarket from Crucial) and ideally clone the disk out to an SSD. Do the memory first.
Don't think the GTX1050 is a huge card regardless of who makes it so it should  fit OK. HDMI > telly is just fine.
Posted : 23/02/2018 4:47 pm
You'll need an adapter.
https://www.amazon.co.uk/DisplayPort-HDMI-Converter-Adapter-Male-Black/dp/B0027HYK7S
 I’d go 8Gb (get an extra 4 aftermarket from Crucial) and ideally clone the disk out to an SSD.
For playing videos?
Posted : 23/02/2018 4:52 pm
Dont forget your ANT+ (or bluetooth) USB dongle.
Also, no problem going from DisplayPort on your PC to HDMI on the TV, you can buy a cable to do just this...
http://www.amazon.co.uk/AmazonBasics-DisplayPort-HDMI-Cable-1-8/dp/B015OW3M1W/
It is worth noting however that its not possible to go the other way round (DisplayPort monitor to HDMI on PC). I recently learnt this the hard way!
Posted : 23/02/2018 4:56 pm
You need a decent-ish graphics spec.
It doesn't say what the integrated graphics spec is, but it would be worth finding out. The min spec is on the Zwift website.
Posted : 23/02/2018 6:02 pm
I am running Zwift on the worlds oldest computer 🙂
It was one of the first machines running Win XP. I have upped the Ram as much as I can and managed to get it to run Win7 and spent £30 on a bare minimum GPU and it does work. Runs Zwift fairly happily on medium resolution setting wgci looks OK on a 32" flat screen TV with HDMI cable.
My biggest limitation is a max 2 mps internet connection
Posted : 23/02/2018 7:01 pm
