Canon DSLR 700d pro...
[Closed] Canon DSLR 700d problems + recovering photos
The wife's new DSLR camera keeps getting a error reading the memory card and losing all the Xmas photos. Usually after I've used it so its always my fault!
Using a canon dslr 700d with a PNY Sdhc class 10 16gb memory card.
Camera says Card cannot be accessed reinsert/change card or format card with camera.
Any ideas why causes it and how to stop it? She's reformatted the memory card a few times but it keeps happening.
Also any ideas on how to recover the photos from the memory card?
Posted : 29/12/2013 1:25 pm
Google photorec and testdisk. May help recover the pics.
Sounds like a crappy sd card, can you try another?
Posted : 29/12/2013 1:37 pm
Yup, if a card gives the slightest sign of having issues, bin it and use another. Preferably a SanDisk. If you've lost files, first port of call is a different card reader / slot / computer.
Posted : 29/12/2013 1:41 pm
If you still have the receipt you can send the card back as faulty.
Posted : 29/12/2013 3:00 pm
 cp
photorec for image recovery - works great.
it sounds more of a memory card error. Have you tried another card?
Posted : 29/12/2013 3:09 pm
Sandisk recovery program if its one of their cards, if not Piriform Recuva usually does a decent job
Be sure to format the card in the camera, not on a computer
As said above new card would be the best bet
Posted : 29/12/2013 4:47 pm
Nice one will look at those programs for photo recovery before replacing memory card
Posted : 30/12/2013 7:46 pm
will look at those programs for photo recovery [s]before[/s] while replacing memory card
FTFY.
I bought a set of unbranded, (actually Toshiba made) 8Gb SDHC cards from 7dayshop.com, four for fifteen quid, IIRC, and none have given me a problem in my Lumix, so it might be worth getting several different makes from them, say a Transcend, a Sandisk, and a Kingston, that way you can get a better idea if it's a camera or media issue.
I've taken thousands of photos, and the only issue I've had was with a MicroSDHC card in an SD adaptor, which was flakey.
Posted : 30/12/2013 8:59 pm
I would buy a new one anyway. Prove the old one doesn't work and take it back, or if it does work (after a low level format in the camera for example) then keep it as a spare. I loose count the number of times I forget my memory card, or forget to take the pics/footage off it and need the extra space, I've had them go funny before too (although some years ago). A spare is often invaluable.
I'm a canon/gopro user and have found the transcends great value for money (if not so great for high bitrate video if you use magic lantern).
Posted : 30/12/2013 9:06 pm
