Can someone tell me...
[Closed] Can someone tell me what's wrong with this forumla?
I'll go away then..
=SUMPRODUCT((NAT!F1:F1000=TODAY()-7)*(NAT!$D$1:$E$1000="design"))
It's a functioning formula was counting occurounces of something else; but I've changed the underlined bit to use first rule as occurences where the date in column F is 7 days before current date, but it's counting 0, when it should be counting 30.
Any ideas?
Ta in advance.
Posted : 27/10/2013 1:26 pm
More brackets?
=SUMPRODUCT((NAT!F1:F1000=(TODAY()-7))*(NAT!$D$1:$E$1000="design"))
Posted : 27/10/2013 1:33 pm
Thanks Dave, didn't fix it but I've just realised that it wouldn't work anyhow, as I want to count all the occurences [b]up to[/b] 7 days previous, so today(),today()-1,today()-2 etc.
Posted : 27/10/2013 1:36 pm
Your use of SUMPRODUCT seems to have an implied IF for each array - in my experience it doesn't work like that. Try putting IF statements explicitly - don't know if that will work, but if it does it will allow you to use a "less than" criterion on the date.
Posted : 27/10/2013 1:41 pm
If in doubt I always throw more brackets at an Excel formula problem! ๐Ÿ˜€
When that doesn't work I start stripping bits of the formula out and put it into a different cell, breaking it up to make sure that each part does what I expect it to.
Posted : 27/10/2013 1:42 pm
Everything works in the formula, except when trying to change the first array to look at a date range instead of a static value.
Beyond my already limited excel skills here!
Edit: Ah, Greybeard you've probably got something there - ta.
Posted : 27/10/2013 1:47 pm
shouldn't you all be building things out of matchsticks?
Posted : 27/10/2013 1:48 pm
use the "--" operator to change the logical (TRUE/FALSE) return of an array to a Numerical one (1, 0)
i.e. =SUMPRODUCT(--(NAT!F1:F1000<TODAY()), --((NAT!F1:F1000)>(TODAY()-7)),--(NAT!$d$1:$E$1000="Design"))
Posted : 27/10/2013 1:52 pm
I think Stoner has a better handle on arrays than I do - I need to go and learn up on that! I'll go with what he suggests.
Posted : 27/10/2013 2:12 pm
Thanks Stoner. My head hurts now and I can't get that to work, giving me a value error.
I [b]am[/b] trying to figure it out! ๐Ÿ˜•
Posted : 27/10/2013 2:16 pm
it might be the $d$1:$E$1000 bit, I didnt test it on that. bear with me a minute.
Posted : 27/10/2013 2:18 pm
yeah, it is. WIll fix it. One tick.
Posted : 27/10/2013 2:19 pm
=SUMPRODUCT(--(F1:F1000<TODAY()),--((F1:F1000)>(TODAY()-7)),--(D1:D1000="Design"))+SUMPRODUCT(--(F1:F1000<TODAY()),--((F1:F1000)>(TODAY()-7)),--(E1:E1000="Design"))
Not pretty as its the sum of two SUMPRODUCTs because my brain cant get it to work with an OR or a two column array. I shall see if I can simplfy it.
Posted : 27/10/2013 2:24 pm
here we are, you can put the OR ("+") bit in one array reference
=SUMPRODUCT(--(F1:F1000<TODAY()),--((F1:F1000)>(TODAY()-7)),--(D1:D1000="Design")+--(E1:E1000="Design"))
so more easily written to see how it works:
=SUMPRODUCT(
That last bit is getting Excel to work out True or False whether D = Design, converting that to 1s and 0s, and then "adding" a second array of 1s and 0s derived from asking E = Design. That combined array is then multiplied against the first two arrays which are pretty straightforward.
Posted : 27/10/2013 2:27 pm
Thanks for this Stoner, but it might be a step too far for a Sunday!
It's giving a count of 0 ๐Ÿ™
The source data is in date format (double checked)
If it's any help, this is the original formula that does what I want it to do, except I want to replace the word "Interfaces" in G, for a date range 7 days prior to today in F (I think you know that though!)
=SUMPRODUCT((NAT!G1:G1000="Interfaces")*(NAT!$D$1:$E$1000="design"))
Completely understand if you've had enoug with this one - you've helped me plent of times previously!
Posted : 27/10/2013 2:30 pm
hmm, it's working here.
how about building it up in pieces first. Just try
=SUMPRODUCT(
first on a shorter range of say 10 sets of dates and see if it comes up with the right number.
Posted : 27/10/2013 2:32 pm
ah, try this then
=SUMPRODUCT(((TODAY()-7)<F1:F1000)*(TODAY()>F1:F1000)*($D$1:$E$1000="Design"))
Posted : 27/10/2013 2:44 pm
Ha, it's simpy not got the worksheet reference in!
Excellent work as ever ๐Ÿ˜€
Thank you very much, and for the explanations as well.
EDIT: Ah, that's a reassuringly familar version! Thanks again for you time, =SUMPRODUCT(((TODAY()-7)<NAT!F1:F1000)*(TODAY()>NAT!F1:F1000)*(NAT!$D$1:$E$1000="Design")) works a treat ๐Ÿ˜€
Posted : 27/10/2013 2:45 pm
TBH, I think I ended up overcomplicating it with the double unary ("--").
It doesnt actually need it. My last formula, based on your first, will work - once you;ve put your sheet refs in, naturally ๐Ÿ˜‰
Posted : 27/10/2013 2:47 pm
Ewer forumla is rong, it shud beee a formula
HTH. ๐Ÿ˜‰
Posted : 27/10/2013 2:52 pm
