Hi All
My old Potterton profile 60e boiler has been playing up for the last year ,ย it gets stuck in the start up cycle (when system is running warm i.e. heating has been on - reached temperature and boiler switched off, then when heating drops below temp and it trys to start up again - so probably dry joints on pcb at fault)
A bang on the side usually fix's it
I have bought a replacement PCB board - which may fix it - But having opened up the front and looked at the rats nest of cables , i dont fancy fitting it myself and risking completelyย borking the boiler
Can any recommend any one in the Brighton area to install the board ?
Alternatively whats the current go to boiler for doing a straight swap of a vented boiler (Not Combi), looking for something thats not going to need costly servicing every year -(Basically apart from hovering up soot from burners - nothing has been done to the potterton for the last 25 years..)
