Just a throne cubicle! It would be too small for a shower, risk of leaks, plus you have all the additional baggage to find space for, larger fresh and waste tanks, water heater, another waste drain.
I'm going to add in a mobi washer hose and trigger in the boot. And a weighte shower curtain that will hang between the open rear doors.
That'll be fed from my fresh tank and onboard pump.
Be good enough for cleaning me up before i get inside 🙂 + bike wash if needed
I have a hoselok connector and valve under the van and run a normal hosepipe from it, gets used for cooling off sweaty horses and muddy bikes. I've got an old dirtworker but never got around to butchering it for the pressure washer parts.
If you keep the Mobi washer complete, you could fill it with a kettle full of water and have a warm shower 🙂
I don't have a mobi washer.
I just saw the handle for sale for 30 quid with a shower head attachment . It's a nice robust handle compared to all the different adjustable hose heads I've had over the years an it seems to have been design to not use loads of water 🙂
Warm is over rated 🙂
