Camera Novice - Len...
[Closed] Camera Novice - Lens advice please
Bought the wife a Panasonic Lumix DC-GX800 camera for Xmas. It has 12-32 lens with a Micro 4/3rds fitting.
She would like more of a zoom lens for taking scenery shots.
What should we be looking for as a lens upgrade. Not too costly please.
Posted : 20/03/2018 2:34 pm
Not that much choice in that lens standard I don't think.
https://www.jessops.com/accessories/lenses/-/micro-four-thirds?fhl=lens_type%3E%7btelephoto%7d&fh_view_size=21&fh_sort_by=lprice&xslp_filterType=simple
Sorry - don't know anything about the system - might be an adapter ring available to use other lenses. Or that 45-150mm at the top of the list. Not particualrly fast but it's not going to be at that price for that (equivalent) zoom length. A bit of a jump between that and her other lens which could be a faff. Most people with a couple of variable length lenses would like them to overlap a little.
Posted : 20/03/2018 3:01 pm
https://www.dpreview.com/products/search/lenses#criterias=SpecsCoreParams%2CSpecsLensMount&paramSpecsCoreParamsLensType=ZoomTelephoto&paramSpecsCoreParamsSubcriteria=LensMount%2CLensType%2CAdditionalFeatures&paramSpecsCoreParamsSearchType=Simple&paramSpecsLensMount=MicroFourThirds
That's a list of micro-4/3 telephoto lenses to browse through, you can mix-and-match camera and lens as they're all compatible.
The 45-150 is definitely the entry level lens to see if its the range you want.
Posted : 20/03/2018 3:09 pm
I shoot M4/3rds mainly with the Olympus PRO range which are lush but pricey.
Heres a list
http://www.four-thirds.org/en/microft/lense.html
Posted : 20/03/2018 4:13 pm
Cheers guys
Posted : 21/03/2018 3:56 pm
You'll probably need in-lens image stabilisation as that camera doesn't have it onboard. It may be easiest to stick with a Panasonic lens for this reason.
Posted : 21/03/2018 10:23 pm
