Bulged disc in neck...
[Closed] Bulged disc in neck?
There's what could best be described as a bulge on one side of a vertebra in my neck. Not big enough to see, but I can feel it. If I tilt my head the other way, I can feel it swap over to the other side, and if I hold my head slightly tilted it'll be balanced on each side.
I've got no real symptoms apart from a bit of a stiff neck that I put down to this cold. I've felt it before, last time I had a cold a year or so ago.
Bulged disc, or impending death? Anyone had similar?
Posted : 08/10/2015 9:52 am
First symptom of Cat Aids ,that is...The bad kind.
Posted : 08/10/2015 10:04 am
Could be Ganglion if it was a bulging disc it would tickle a bit.
Posted : 08/10/2015 10:22 am
Could be all sorts but won't be a disc - they are a long way from anything superifical.
Worth getting someone to have a look (gp) if persists
Posted : 08/10/2015 10:30 am
I've currently got a bulged disc at C6-C7 pressing into my spinal chord.
My only symptoms are neurological - my legs have gone a bit weird.
Waiting for an op as we speak.
You'll have to see a doc. If your guess about what's wrong is correct it won't fix itself.
Good luck.
Posted : 08/10/2015 10:36 am
vertebra
Vertibra. Get it right.
Posted : 08/10/2015 10:45 am
Hmm, well with no neurological symptoms, maybe it's just some kind of dreadful cancer.
Posted : 08/10/2015 11:53 am
I've currently got two bulged discs at C5-C6 but not pressing into my spinal chord. I have some symptoms which revolve around my left arm and the nerves being squeezed. Having physio every 3 weeks and looking at ~ 6 months more to strengthen the neck and reduce the pressure on the nerves.
If you've got a bulged disc I'm fairly sure you'd have symptoms and you should get it checked out. HTH
Posted : 08/10/2015 12:24 pm
