Brewers of STW
[Closed] Brewers of STW
DMS is not such a big problem with UK 2 row malts, it's more American 6-row and pale European Pilsner malts, so you might not need to worry depending what you're using. For some reason that I can't explain I don't like boiling off half my wort, I know I can just replace the water but it just seems so inefficient somehow. I've only really used Maris Otter though, so maybe I've just been lucky!
There was a comment earlier about overpitching, apparently the 11g packets are sometimes considered to be almost underpitched for a ~20l brew so I used 1/2 a packet in 5l. The primary seemed to work really well as far as I could tell, but the secondary took over a month (I was expecting ~2 weeks). I don't know whether it was over attenuated or if I'd stressed the yeast somehow, I'm going to try again this weekend, and be a bit more careful.
An interesting experiment in pitching rates here: http://sciencebrewer.com/2012/03/02/pitching-rate-experiment-part-deux-results/
Posted : 06/10/2014 1:25 pm
Cheers for the advice re finings in secondary - that's actually ringing a bell, and I'm sure I've got some isinglass somewhere. I'll have to go through my records to see whether it was from my early beers or maybe the wines I made prior to that.
Will do some research on gelatin vs isinglass.
Posted : 06/10/2014 7:27 pm
a starter for ten then 😉
gelatin comes from pigs' trotters; isinglass comes from fish
so both no good for strict vegetarians
the isinglass I use is marketed as "Vinclear" and the instructions refer to "the wine" but it works fine (no pun intended!) for me in beer too
Posted : 06/10/2014 8:29 pm
crash chilling prior to kegging
If you're kegging it then you have co2 available?
This is my usual process and I get crystal clear ales from it.
Cold crash down as cool as you can go. Blossom some gelatine a little cooled boiled water. Purge seconadary with c02 to prevent infection then add you gelatine water and rack the beer onto it. Hold it at the low temp for 48 hours then keg.
Posted : 06/10/2014 8:55 pm
Thanks all, will try racking to secondary and adding finings.
Yep, got CO2. I normally purge my kegs with it prior to filling them, will do the same with the secondary.
Posted : 06/10/2014 10:48 pm
To prevent infection or oxygenation?
I purge my secondary FVs before racking to get rid of oxygen, particularly if the beer is going to be in there for a while, but didn't think it had any effect on infection risk?
Posted : 07/10/2014 7:58 am
i assume by purging an FV you are just filling it with c02 basically?
Posted : 07/10/2014 11:15 am
Yes. To be honest, it's probably not very necessary and I don't use secondary very much anyway, but if I'm transferring something for a while (like an RIS) then I'll fill the FV with co2 before filling with beer.
Posted : 07/10/2014 12:23 pm
You only need to drop a bit of Co2 into the keg as its heavier than air so will sit on the bottom until its displaced by beer. Once you close the lid (assume a corny keg) then purge the headspace and your beer should be OK for a while.
Posted : 07/10/2014 1:31 pm
so, opened may latest bottled brew after 11 days in the bottle and... meh.
it tastes a lot like the others tbh. a bit sour almost, like there is no hop aroma, just quite bitter. not undrinkable, but its not getting better. wife remarked on the smell of yeast so clearly i'm dragging a lot into the bottle and my pouring wasn't the best. plenty of fizz with a generous half teaspoon of sugar- almost too much i think as it was lager fizzy, but at least i know a level half teaspoon is enough.
got quite a dunt off it so i think the ABV is up there, but i wont relish drinking the rest in a hurry. i think i'll leave this batch for a few months and retry.
anyway, any homebrewers in the central belt of scotland? i could do with a distinguished palate to critique my brew and help decipher what the various flavours are, because after 5 brews that all tasted pretty much the same i can't tell whats gone wrong in the process 🙁
Posted : 09/10/2014 8:20 pm
Sour doesn't sound good. What kind of sour? Vinegar sour or chemical sour?
What do you use for cleaning/sanitising?
Posted : 09/10/2014 9:35 pm
hard to put my finger on it j_d, definitely not a germoline / chemical smell and not obviously vinegary either. its more organic than chemically taste. aroma from the beer is almost always not as bad as the taste. head retention isn't great on the beer either. it just tastes a bit bitter, but its a fairly consistent taste that i've got from all my brews.
cleaning wise i use vwp, lukewarm water and a triple rinse. sani wise i use starsan, 1.6ml / litre or 8ml for 5l measured using a small syringe so near as dammit accurate, unless my dilution ratio is off.
Posted : 09/10/2014 9:46 pm
Moar hops, David.
Seriously, try brewing a hop monster and see how that goes. There's a reason homebrewers go for big abus - it's actually v difficult to successfully homebrew a light, subtly flavoured ale.
Posted : 09/10/2014 9:55 pm
I hate VWP. Lost loads of brews to it and the resulting phenols until I switched to beer line cleaner. Not had a phenolic brew since
Posted : 09/10/2014 9:58 pm
Remember that for bottle conditioning you're effectively starting a second fermentation when you add that sugar, so after 11 days, whilst is might be carbed up, its unlikely the yeast will have finished up what they need to do to clear up the beer.
With few execeptions, the last bottle in my batch is normally the best one.
In my first half a dozen batches I had off flavours galore, so drinking anything in the first couple of MONTHS normally meant I was picking up those off flavours. Fine tuning in processes has removed pretty much all of those, but I'll still occasionally open a bottle at two weeks and think "bollocks" only for it to turn out great after another month in the bottle.
Where abouts are you David? I'm in Glasgow, more than happy to meet up and share a few. I'm no expert by any stretch of the imagination, but have just very recently been through the same stage youre at now so might be able to help. All 6 beers I entered into the national homebrew comp all came within 2 points of each other, so at least I appear to be consistent if nothing else! 🙂
Another thing to consider is your water. My dark beers tended to fare much better than my pales, which were lifeless and a bit meh. For £18 I got a full water analysis along with water addition recommendations for different styles. Its really tramsformed my pale ales.
Also, I definitely agree with the more hops suggestion. Try not having any hop additions until the last 20 mins, then start adding around 100g for 10l (which will give you IPA level IBUs). No puckering bitterness, just loads of hop flavour and aroma. Kernel style
Posted : 09/10/2014 10:01 pm
i was wondering about a brew with no bittering hops to see if its a bitter flavour from boiling them, so might just go daft with hops on one brew. the frustrating thing is the lead time to find out its not as good as you hoped 🙁
j_d any links to the beer line cleaner? i dont know if its relevant but the last few times i've used my youngs autosyphon it seems to have introduced bubbles in the syphon (god knows how as its submerged) just wondering if that might be an issue as the beer tastes different between racking to bottling fv and after its carbonated in the bottle (which i'd expect to a degree)
lots of things to tweak. i am near the williams bros brewery and know someone who works for them so half inclined to send a bottle their way and ask for their opinion on what the off flavour is. i'm certainly not going to be stealing their market share any time soon:)
Posted : 09/10/2014 10:05 pm
hey pf- would be good to meet actually, could even combine it with a bike ride if you fancy it. can't make a brew but can still chuck a leg over 2 wheels 🙂
its a fair point on beer age, because the stash is kept in the house now i dont think any brew has lasted >1 month really, so it might be too young still. there is a bit of sediment in the bottles but not tons of it. i'm sure i will crack it but i was hoping this brew would have been a bit of a eureka moment, not a urea moment 🙂
Posted : 09/10/2014 10:12 pm
I always have the issue with my pales David, they taste incredible in the bottling bucket, only to have lost that once carbed up, only for it to turn into a wee cracker a while later. Give it another month and then reevaluate.
Oxygenation is an issue, but you shouldn't be picking it up at 11 days.
Honestly, when I read your posts I feel like it was me writing them a year ago. Gradually every part of your process improves, bit by bit, subtly. Before you know it, your beer has gone from "this is drinkable, but I don't like it" to "this is pretty darn good!"
Lots of small improvements and changes and practice and it will get there.
I was never truly happy with any of my beers until fairly recently, but I've currently got 6 different styles bottled up which are just random recipes off the internet and I'm happy with how all of them have turned out. I couldn't tell you one major thing Im doing differently now that's led to that, but I could probably list 100 small things I do differently!
David, if you've drank all your batches within a month then Im not surprised you've not been happy with them! Seriously, give them time to sort out all the off flavours. I bottle up half a dozen 200ml bottles with every batch. I don't touch anything for 2 to 3 weeks and then sample a 200ml every week or two until I'm happy it's ready.
I'd say I start drinking IPAs from 6 weeks in the bottle, porters 8-12 weeks, stouts at 8-12 weeks.
Get a pipeline going and you won't even notice the time passing!
Posted : 09/10/2014 10:19 pm
Just bagged up a big pile of hops. Hopefully I will have time to try a batch over christmas.
Posted : 09/10/2014 10:20 pm
try here: http://www.morleyhomebrewcentre.com/ucommerce/cleaning-sanitiser/pro-kleen-purple-beer-line-cleaner-5ltr/c-23/c-162/p-1206
basically a capful or two per gallon of lukewarm water. Let anything that's going to touch the beer after the boil sit in it for 10-15 minutes, then rinse well as normal. That includes your bottles and caps, siphon tubing, little bottler, spoon for priming sugar etc
Also, don't forget the campden tablet per every 5 gallons of brewing liquor.
finally, +1 for giving the beer time to mature. Mine usually take 2-3 weeks to carbonate & only then do I move them somewhere cool and leave for at least another 3 weeks. Longer = better
for siphoning I keep it simple: one of these: http://www.morleyhomebrewcentre.com/ucommerce/equipment/bottling-aids/youngs-simple-syphon/c-23/c-231/p-1913 plus one of these to replace the little tap thing: http://www.morleyhomebrewcentre.com/ucommerce/equipment/bottling-aids/automatic-bottling-stick/c-23/c-231/p-1909
Posted : 09/10/2014 10:25 pm
PSA...
I work for a brewery in Hampshire (Bowman Ales), and I currently have several hundred empty 500ml brown bottles that I'm about to throw away. They have our labels on them and need washing, but they are undamaged. They came from a batch of beer that had quality issues.
I just wondered if anyone wants any of them. I can possibly deliver them in Hampshire/Southampton/ Portsmouth/Chichester/Swinley/ QECP/ Fleet/Andover. (Obviously you don't have to take all of them, I can do them by the (malt) sackful!
Either reply on here or to luke.d999 AT gmail.com
Posted : 11/10/2014 9:51 am
Anyone got a recipe for something easy to drink and ready in 3 weeks from brewing?
I've got a birthday party Nov 15th and was planning on 2 brews. My first (a Black IPA) is going to be in the fermenter for another week, so I can't do another until then....
Posted : 14/10/2014 4:31 pm
3 weeks? unlikely. bottle conditioning takes at least that long, and that's from fully fermented.
you could always buy another fermenter, they're only a tenner. but it won't get you another brew ready to drink by Nov 15th
Posted : 14/10/2014 4:45 pm
Any brew will be ready to drink after 3 weeks. Probably not at it's best though.
This was one of the first beers I made purely because of the speed (and the simplicity of the recipe!). It's a wit (like Hoegaarden) and they tend to be best drunk fresh. It was really good after about 10 days fermenting and then 10 in the bottle. [url= http://www.jimsbeerkit.co.uk/forum/viewtopic.php?f=5&t=38303&sid=cf236497d5a1bdf055d8aa83ed0d7f8f ]http://www.jimsbeerkit.co.uk/forum/viewtopic.php?f=5&t=38303&sid=cf236497d5a1bdf055d8aa83ed0d7f8f[/url]
Posted : 14/10/2014 5:06 pm
I suppose so
to be honest mine take 10-14 days just to get through primary fermentation & the bottling bucket, and they need another 2 weeks on top of that for in-bottle carbonation. I guess you could keg it & squirt some CO2 in to force carbonate, that way I guess it [i]could[/i] be ready in 3 weeks. but as you say, it wouldn't be at its best. I'd certainly move the keg to the party location ASAP to allow it time to settle
Posted : 14/10/2014 8:38 pm
Ok, I'm gonna do the standard Wit Beer off of Brewsmith.
Off to the homebrew place tomorrow and will buy a new fermenter and brew it that day which will give me 4 weeks + 2 days.
Posted : 15/10/2014 8:55 pm
OK Booze Team, some success.
Doing a simple Wit, using my refractometer and thermapen and (biggest change) a big wide grain bag I just came within 0.0001 g of my target initial gravity.
Sweet.
Posted : 17/10/2014 3:12 pm
So after years of wanting to brew I've done a days brew course at a local brewery, love the mash stage and now my days work is fermenting downstairs, I must admit I'm a bit nervous about the next stage, siphoning and bottling, would be a shame to go and cock this stage up. Any tips greatly appreciated whilst I read through this thorough post. Cheers
Anyone experimented with adding fruit peel, wondering how pomelo peel would work, I'm getting ahead of myself.
Posted : 29/10/2014 11:57 pm
Hey, good luck with the first brew! I discovered the root cause of my siphon working badly at the weekend. I'd put a nylon filter bag over the end of the siphon at the FV and it was causing the siphon mechanism to suck in air around the seal, instead of sucking in the wort. Once i ditched the filter bag it worked like a charm. sadly i'd stirred up the wort a good bit by this time so it was pretty cloudy by the time i got it into the bottling bucket. There was a small amount of splashing too when it started. I took the opportunity to use one of the c02 capsules i got for pressurising my barrel to purge the secondary FV and let it sit for a good few hours to settle.
so, my top tips would be:
1. take your time. i used to think any exposure to oxygen was bad, but its not bad enough to warrant you rushing and making a hash of it 🙂
2. make sure your bottles are spotless - clean throroughly, rinse well and look through them at a bright light - any remaining gunk will be easy to spot.
3. buy a little bottler, a bottle sanitiser and a good bottle capper. the expense is worth it!
good luck!
Posted : 30/10/2014 1:55 pm
Thanks David, that's reassuring advice.
I'm due to bottle Sunday, would it hurt if I left a day or two? Fermentation has slowed down a lot so I think it's ready.
Posted : 30/10/2014 9:23 pm
Fruit Peel
Yes, Done it with the remains of pressed oranged froma juice factory.
Blanched them with hot water to pastuerize and kill off wild yeasts , then left in a CT for a week after primary . Used approx 100gm/gall iirc.
Leaving it an eaxtra day wont make a jot of difference imo , probably be better , just remember to do 3-4 pet pop bottles and leave them in the airing cupboard . will let you know aboyt conditioning levels quicker and if you need to warm or cold hold your bottles
Posted : 30/10/2014 10:46 pm
The Wit beer I made needed orange peel.
I got some (from Curacao oranges) from the home brew store. Came as hard little dark things, not like orange peel at all.
Dunno if it's going to be ready in time for my party though. Not quite ready to bottle yet and it's two weeks on Saturday. Hopefully I can bottle at the weekend. Got 6 SGs to drop by then
Posted : 31/10/2014 4:57 am
@Peterfile
Since increasing the size of your stockpot have you increased the volume of water that you mash with to a nearer full volume BIAB?
Posted : 17/11/2014 5:50 pm
I have had a lazy couple of months brewing-wise i.e. have done nothing! Finally got around to doing my Christmas brew yesterday (a nice porter that I've done before but with a Christmas pudding in the FV!).
I also bottled the beer which had been in primary for 2 months. I was pretty apprehensive as I'd heard when the yeasties run out of sugar they basically cannibalise each other and the resulting by-products do not taste nice. [i]However[/i] I've also heard that with small-scale brewing (I only do 10L at a time) you can get away with more for some reason (e.g. virtually impossible to over pitch).
Anyway the beer (a Belgian blonde) tasted amazing straight out of the FV, probably one of my best so far - really smooth flavour already and no off-flavours that you sometimes get in a "young" beer. It made me think that regarding conditioning the beer, maybe time on the greater volume of yeast in the FV is worth more than time in the bottle. Thoughts?
Posted : 17/11/2014 6:00 pm
The main reason I increased the size of stockpot was so that I could do a full volume BIAB, and also to ensure I was getting a full 10l into the fermenter. I now don't need to dunk sparge or top up the boil volume, I'm still hitting 70% efficiency and I've obviously got one less step to do 🙂
I've been putting together some drawings for a recirculating mash BIAB set up. But getting all the parts I need is coming in at around £500 (including chiller etc). After a chat with NZCol today, he's put me on to a prebuilt unit that's designed almost exactly the same way, but obviously avoids the need for me to faff about with metalwork and electricity (which I was half looking forward, but half dreading). Even better, it costs the same as my proposed DIY build!
I'm still brewing every two weeks (which is actually slow down since I've now got limited space in my fermentation fridge), but reckon I must have brewed more than 30 batches now.
Latest has been a Chocolate Oatmeal Stout which I added 100% Madagascan black cacao to the boil, then soaked some cacao nibs in dark rum and added them to secondary. I've just bottled it and will leave for a few months before getting stuck in.
I thought a while back that some of my pales were being limited by the quality of the hops I was picking up. The state of the hops on opening the packets was so hit or miss. So after a few chats with guys from a local homebrew club I was put on to a US company called Nikobrew that nitrogen flushes their hops at packaging and have a reputation for selling some of the best hops in the US.
I bought 1.5kg of mixed (expensive variety) hops in little 50g packs (which is perfect!) for £70 including shipping to the UK. So that's £4.60 per 100g including shipping...which is cheaper than what I currently pick up hops for here! I just finished a brew with them on Wednesday and I honestly cannot emphasise enough how incredible they smelled. "Dank" would be a good word to use. Really really looking forward to tasting the finished product.
I've also started buying milled to order grain from Malt Miller. Which again, surprisingly, works out cheaper than the run of the mill (sorry) pre-packed stuff.
Other developments have been the purchase of a PH meter (which hasn't arrived yet), since I've done so much work around water chemistry that it seems odd to be blindly accepting the calculations as being correct. The little PH strips I've been using are absolutely rubbish 🙂
I entered half a dozen random beers I had lying around into the UKNHBC to see if the judges would pick up any off flavours that I wasn't. Surprisingly, all the beers did pretty well (within the "very good" category) and the majority of marks I lost was down to being out of style (eg using Australian hops in American Pales etc) rather than for flavour/aroma/body/off flavours etc. So pretty encouraging all round.
Next up is trying to find a 20-25 litre fermenter that will fit my fermentation fridge so that I can brew a larger volume without having to change the FF. Once I find the fermenter, I can start building a draught beer set up...which means I can drop bottling the beer!
Posted : 17/11/2014 6:53 pm
Ha! We seem to be heading down the same path, albeit I'm somewhat behind you...
I was looking at building a braumeister style thing but the grainfather (I assume you're talking about) seems to fit the bill. Although I do wonder how long the 2kW element will take to heat the water.
I really want to go 60L brew length though so I may end up with my design yet...
I brewed this http://www.insidebeer.com/articles/20100527 at the weekend, hopefully it'll turn out alright, was an amazing colour.
Think I might try the full volume BIAB if you're hitting 70% with it, seems like it's not worth doing anymore faff if it's working for you and you're hitting your volumes into fermentor.
Great tip on Nikobrew, thanks for that. Also if you tell Rob the Maltmiller that the grain is for BIAB he does a slightly different crush for you. I think there is a notes thing during checkout.
Very well done on your results at the beer marking, I need to sort a few things out prior to attempting that, like water treatment and temp control on the fermenting cupboard.
We should do a recipe share, are you using beer engine?
EDIT: Perhaps we can do a joint order to Nikobrew at some point if it saves costs
Posted : 18/11/2014 9:53 am
We do indeed seem to be heading in the same direction clobber! Yeah, it was the Grainfather that Col was telling me about. He's got one arriving imminently from NZ.
Part of me wants to do the DIY build because it's good experience, but the other part says just spend the same amount and buy a proper one! Re the 2kw element...probably wouldn't be too much of a job to drill a hole and stick in another 2kw element to use when bringing up to temp? Would need to plug it into a different ring main though.
That imperial stout looks nice. I brewed a RIS last year, but at that time a few of my processes were a bit loose and I oxygenated the wort when bottling, which meant that the beer turned a bit grim before it had the chance to fully mature.
I'm keen to keep brew length fairly short at the moment, simply because it means I get to brew more often. Honestly, even if I had to throw away all my beer once it was ready, I'd still brew as a hobby! The fact that I get a case of "free" beer at the end is just a major bonus.
Cheers for the tip on malt miller. I honestly can't recommend Nikobrew enough. I'll let you know what the taste verdict is in a few weeks, but based on aroma alone they are in a different league to the stuff I've been getting a hold of.
I'd definitely recommend picking up a 19l pot and doing a full volume mash, it's just so much easier, quicker and cleaner. Also, whilst the mash is almost at the top of the pot, it means that you've got loads of headroom for the boil (rather than the massive brewery inch, which is prone to boil over).
I use beersmith, but most of my recipes are now on paper records, since I find it easier to take detailed notes during the brew and to reference back to. I could scan some of them in and email over.
Have you seen the [url= http://www.syneksystem.com/ ]Synek[/url]? Very tempted by one of these. You fill up 8 pint (I think) bags with your beer and they keep for yonks. Then, whenever you fancy a particular beer, you drop that bag into the unit and dispense as normal. Seems like a nice and small kegerator unit. Just keep the filled bags in a cool place/fridge until you need them. Apparently the beer lasts 30 days even once you've poured the first pint.
Definitely up for that...although I've currently got enough for somewhere between 15-25 brews so might not be for a while! Although, I'll probably be bored of Citra, Cascade, Centennial, Amarillo and Galaxy by then, so maybe we could do a swap of a few.
Posted : 18/11/2014 10:09 am
i'd be up for a hops group buy too. I've been getting my hops from Brewuk and they seemed fine, but i'm not experienced enough to know if they are great.
i've just ordered a custom BIAB bag as i was sick of the one i had not quite fitting properly, and i think i'll ask for the water treatment for Christmas, 2015 with be the rise of Potters brewery!
Incidentally what do you call your brewhouse? I called mine Potters because the magic happens in the cupboard under the stairs. More like David blaine at the moment to be fair - stuff hangs around in there and doesn't do much for a couple of weeks and it smells a bit funny when you let it out 😉
Posted : 18/11/2014 10:23 am
Just looking at Nikobrew's site, they have a flat rate of $25 on international shipping up to 3.5-4 lbs. Probably wouldn't save much doing a group buy and will increase risk since it's uninsured (I'd rather 1.5kg of hops went missing than 4.5kg!). Plus we'd also have the time/cost/hassle of splitting and posting on the hops to the others once they arrived in the UK.
I've not got a name for mine david, but quite like the sound of the Whistling Nostril 😉
Brewuk's hops are decent, but just wait until you open a pack of Nikobrew's stuff! I sat smelling the empty pack throughout the boil last week hahah!
Posted : 18/11/2014 10:34 am
The guy I did my day brew course with has just opened an online brew shop, not bought anything yet but I will in due course. I'm going to try my bottle conditioned pale ale at the weekend, feeling strangely nervous.
http://home-brew-depot.myshopify.com/
peterfile - thanks for all the useful info, this thread is my second favourite on STW, first is the Tripster ATR 😀
Posted : 18/11/2014 11:08 am
Yeah, Peter, you've been very good at sharing your info on here! Thanks!
That synek looks great but pricey! with respect to smaller batches you've obviously not told your friends about your brewin, when one of mine is ready they all pile over and it's gone before I know it hence the longer brew length...
I also want to be able to do a decent size batch for special occasions etc..
Posted : 18/11/2014 11:23 am
Careful, i started with 40 then 60 then 100 then 1500 litres - slippery slope 😉
Posted : 18/11/2014 11:49 am
how many grainfathers can you bring in then Col?
Posted : 18/11/2014 12:07 pm
Just popped a brew i bottled back in early sept, so about 9 weeks in the bottle. Its definitely benefited from more time in the bottle, the off flavours are definitely reduced and the aroma and bitterness are actually mellowed. carbonation, colour and clarity is pretty good too. actually enjoying it, although its not perfect. Fired me up a bit for a brew at the weekend though! I have 100g each of east kent goldings and centennial and plenty of MO. i'm thinking a smash with centennial? I'd like to do something with a hop overload at the end, keep the bitterness down to make sure its not one of the flavours i'm getting.
as a final note i'd echo the thoughts above too. this is one of my favourite threads on here and the generosity of knowledge, advice and good natured banter is great. Some of the threads on here could do with following this example.
Posted : 18/11/2014 8:09 pm
Maybe what you perceive to be off flavours are just normal flavours produced during fermentation that havent reduced to a low level. Diacetyl is noticable at tiny amounts, DMS at higher levels can guve green beer a skanky nose .
Then there are vicinal diketones (sp) that can make you think your beer is made up of vegetables.
Centenial is a great hop ,try a load in a muslin bag in the FV maybe?
Posted : 18/11/2014 9:53 pm
Good stuff david, glad to see the patience paid off! 🙂
Go for around 100g of hops at 20/10/0 mins...loads of aroma flavour and a nice, rounded bitterness. Play around with beersmith, but you should still hit around 40-50 IBUs just using bucket loads of late additions. Have a read at [url= http://www.mrmalty.com/late_hopping.php ]this[/url] on Mr Malty. I rarely do 60 min additions anymore.
Also, +1 for liking this thread...definitely one of my favourites on here.
Posted : 18/11/2014 10:04 pm
quite possibly singletrackmind, i'm just not sure what i was smelling / tasting to start with as i couldn't put my finger on it!
i'm going to seek out some experienced brewers (i have a line into a commercial brewer) and get their honest opinion on it. i know PF is reasonably local to me (central Scotland) so anyone else local? we could meet for a bike ride somewhere and have a wee tasting session mid ride? might not be conducive to shralping the gnar afterwards though...
Posted : 18/11/2014 10:05 pm
I've tried two bottles of my first batch after 10 days bottle conditioned today, on the whole it's not bad, it's a little tangy almost acidic but has a good nose, I wondered at the time whether I used enough sugar, I was being cautious. I also wondered whether my garage was too cold for storage. I'm going to leave it alone for a few more weeks to see what happens.
Posted : 23/11/2014 6:25 pm
Cracking thread, just spent a while reading through from the beginning. Last Christmas when we were all a bit skint the entire family gave each other stuff they had but didn't use as gifts, and I ended up with the brother-in-law's homebrew stuff. So far only got as far as doing a couple of brews of the same kit (Wilko's Meixcan Cerveza) but I'm keen on having a go at BIAB. So after being inspired by this thread I'm going to put a bit of a shopping list together and wait for my Christmas tips to roll in at work and get everything I need to make a start
Posted : 23/11/2014 8:01 pm
Do it! Great time of year to start too (you can brew on days when the weather doesn't warrant going for a ride and less worry of fermentation temps getting out of hand).
I'm not sure what kit you've got already, but Bazz posted a link to [url= http://www.geterbrewed.com/biab-all-grain-starter-kit-includes-a-mash-kit.html ]this[/url] deal the other day on here. Quite frankly, it's an absolute bargain! I'd be impressed if you could put together a similar package for less.
My PH meter arrived the other day, along with some buffer solution. I've been playing with it over the last few days to see how well it holds after calibration. Initial impressions are excellent. I'm getting accuracy of 0.01 to 0.02! Considering I only need to be accurate to 0.1, it's good news.
Will be interesting to see how far out my water chemistry adjustments are. The beer has been tasting much better since the tweaks, but I suppose I won't know what I'm actually hitting until I test it. Quite excited.
I'm very close to pre ordering one of those Grainfathers. The only thing holding me back is a potential house move, which would mean a dedicated space for brewing and the ability to custom build something. Then again, due to the limited availability I'm pretty sure I could shift the Grainfather with ease if it's no longer needed.
Posted : 26/11/2014 11:45 am
Used my pH meter for the first time last night (it's an Extech PH100, which seems to be a good balance of price and accuracy for brewing).
I was actually a bit nervous when I drew a sample from the mash, since I've invested quite a bit of time learning about the water chemistry side of things (mostly because I find it interesting), and didn't want to find out I was way off the mark.
Brewed an IPA i've brewed before and was shooting for a mash pH of 5.4. By either good science or sheer fluke, I hit 5.41! I'd have been happy anywhere between 5.3-5.5, so really pleased.
I suppose it's also confirmed that the £18 spent on water analysis and initial treatment recommendations from Murphy's was well worth it too. Given that my mash additions were designed to bring down the pH, I wonder what it would have been sitting at if I'd left the water untreated?
I've noticed a big difference in my pales since fixing my water. They were tasty before, but felt a little one dimensional and the hops always seemed muted, regardless of how much I used. Now I feel like the hops are clearer and have a bit more zing to them, more defined.
I'd definitely recommend Murphy's water testing and treatment recommendation service. I emailed the lab a few times afterwards with questions about my report and help with styles and they were always prompt and helpful with their responses. A bargain at £18 IMO if you fancy tinkering with your water.
Posted : 28/11/2014 11:38 am
Don't want to start a new thread so I'll stick this here:
I'm looking for a brewing heat belt for a 25L fermenting bucket - can anyone recommend a good one?
Also are lagers normally hopped? - The belt is a gift for someone who has just started brewing (lager) and is using the tins, however so far they haven't had much luck. I wonder whether I could buy him some posh hops to stick in to improve flavour a bit?
Cheers brew boffins of STW
Posted : 28/11/2014 12:45 pm
I wouldn't recommend one to be honest
a) the heat is too close to localised portions of the brew
b) there's little to no control
and
c) lager yeasts prefer lower temperatures anyway. better to ferment lower, slower for lager. Lager yeast prefers temperatures below 18deg, ideally 12-15. If you ferment at too high a temperature, there's a risk of all sorts of odd flavours being introduced.
Hops are used in lagers, yes. Often Saaz, Tettnang, Hallertauer etc. But if your friend is brewing from kits, there will be hops already in there; you don't want to be adding late / dry hops to lagers, that's more of an ale trick, particularly hoppy ales such as IPAs or American Pale Ales.
Do you know what brand of kits? some will give better results than others. e.g. Hambleton Bard & Coopers kits will give better results than Geordie or John Bull, for example.
Better to change the fermentables - if currently using common or garden sugar, switch to brewer's sugar, or better still, spraymalt (dried malt extract).
Posted : 28/11/2014 2:52 pm
GREAT CALL! Just brewed like this, hitting over 70% with it also. Won't muck about again!
Bigger pot and full volume biab FTW!
Posted : 08/12/2014 3:02 pm
Aye, it certainly makes the whole process a lot easier! 🙂
Also, the 19 litre pot still fits comfortably into my fan oven, so I'm still able to hold mash temps within 0.5 degrees.
I just bottled an IPA that I've brewed before, but this time I used fresh malt and those uber tasty Nikobrew hops. Took a sample when i bottles (obviously!) and it was delicious. Can't wait for it to carb up!
This was also the first beer I've cold crashed. I crashed for 72 hours to drop all of the pellets out of suspension that I threw in for dry hopping. Worked very well, it all formed a nice tight layer on the bottom on the FV.
Posted : 08/12/2014 3:20 pm
hey all, been a wee while since i posted on here previously (my forum name has changed due to going premier, but not too hard to reconcile who i was 🙂 ) hope you are all well.
I haven't brewed for a couple of months sadly.My last creation was a citra double IPA which is quite potent and worked out reasonably well, but the hop burst isn't really shining through. I almost get a note of pine from the Citra hops, but its quite subtle - not unpleasant though.
the thread on the front page reminded me to post here. Thanks to a very generous Christmas present from the GLW I'm off to Stewart brewing in Edinburgh this weekend to brew with them for the day. Quite excited about it actually, i think we have a consultation to decide what to brew, then get on and create something. Go back in 3 weeks time to bottle. I can't wait to get a professional perspective on my skills and hopefully pick up some tips. i'm planning to take one of my bottles along to get their view on it too, so i'll let you all know how it goes!
what temp did you cold crash at PF? 5-6 degrees?
Posted : 12/01/2015 10:23 am
I think I'll upgrade to a bigger pot.
Just re-done my kitchen and put in an induction hob, the Massive Brewery pot is lacking in ferrous metals and doesn't work on it unfortunately.
That eBay 19 litre one looks OK, stainless steel.
Also looks like I'm having to change the central heating system in my flat. While an annoying expense, the upside is that it frees up a big cupboard after we remove the old water tanks.
While I may make it into a sauna, I may also use it as a brewery!
Posted : 13/01/2015 1:43 pm
That sounds fantastic david! Take some pictures!
Whatever temperature my kitchen fridge sits at 🙂 I think it's about 4 degrees!
I've just bottled a hoppy amber. I brewed the amber a while back and loved it, but the thing that struck me at the time was how good it would be with a nice session type hoppy amber. Can't wait to try it.
I've actually not brewed in a month or so (longest for a while!). Might try to rectify that tomorrow!
Posted : 13/01/2015 2:42 pm
Back on the brew here after some months off - can anyone recommend a good stout BIAB recipe?
I'm not a huge stout drinker tbh, but it would make a nice change from the usual IPA stuff I do. Am I right in thinking that you still use a predominant pale malt base for stout?
Posted : 27/01/2015 8:17 pm
I've got belter of an oatmeal stout, great for using up ingredients too!...
This is for 10 litres, so adjust accordingly
1800g pale
500g flaked oats
175g British caramalt
140g roasted barley
135g chocolate malt
115g carapils
60g black malt
60g flaked barley
18g northern brewer @ 60 mins
16g cluster @ 15 mins
67 degree mash.
Posted : 27/01/2015 8:31 pm
I'be got a nice recipe for a double chocolate stout, loosely based on Saltaire Brewery's Triple Chocoholic (speaking of which I've just put a bottle in the fridge for Ron).
And a loverly London Porter recipe too, if that floats yer boat.
Not on the pc tonight so will post them both up tomorrow
Posted : 27/01/2015 8:47 pm
Thks Peter, looks good.
Be good to see those recipes as well John, cheers - don't think I've ever brewed a stout, so keen to give it a whirl.
Posted : 27/01/2015 8:52 pm
i did my brew day too - great fun! I'll post some pics / a long and boring story atthe weekend.
Posted : 27/01/2015 10:13 pm
[b]Double Chocolate Stout[/b]
to make 23 litres at OG 1045 (to give 19 litres in the fermenter) so adjust your quantities as necessary. The nearest commercial beer to this is Saltaire Brewery Triple Chocoholic
3855g Pale Malt
568g Chocolate Malt
219g flasked oats
219g Torrified Wheat
110g Black Roasted Barley
110g Cocoa Powder (well I did say it was a Double Chocolate stout)
Mash at 68degC for 60 minutes
Boil for 90 minutes
44g Fuggles at 90 mins
11g Fuggles at 10 minutes
11g Fuggles at 0 minutes
Ferment at 20degC with Danstar Nottingham yeast rehydrated as per packet instructions
[b]London Porter[/b]
to make 27 litres at OG 1044 so adjust as necessary. I make 27 litres with 4 litres in the dead space below the tap, aiming to get 23 litres in the fermenter. Nearest commercial beer to this is Fullers London Porter
4467g Pale Malt
654g Brown Malt
347g Crystal 120
255g Chocolate Malt
127g Torrified Wheat
mash for 60 minutes at 67degC
Boil for 60 minutes
84g Fuggles at 60 minutes
26g Fuggles at 10 minutes
Posted : 28/01/2015 10:25 am
John, I've done a few chocolate stouts recently. The first one I did was using cocoa powder, but it didn't turn out as great as I expected. After a bit of digging I found that cacao is supposed to be a much better alternative for brewing than cocoa powder.
Managed to pick up a block of 100% madagascan black cacao from wholefoods and added that instead the next time I brewed the recipe...FANTASTIC! Well worth trying it next time you're trying something with chocolate.
My most recent one was experimenting with cacao nibs, soaked in dark rum for a few days before being added to secondary. It's still a bit young, but initial tastings have revealed a lovely, subtle chocolate layer.
Posted : 28/01/2015 11:20 am
sounds interesting, I'll give that a try next time I brew the Choc Stout
Posted : 28/01/2015 11:26 am
Do you find that these stouts can be on the sweet side? I guess that big maltiness is part and parcel of a stout, but it's not something I'd like to go OTT on. Prefer the minerally bitterness you can get with some of them.
Posted : 28/01/2015 1:57 pm
mine isn't especially sweet, but boiling 44g of fuggles for 90 minutes will raise the bitterness level enough to offset the sweetness. You could up the amount of hop to increase the bitterness still further
Posted : 28/01/2015 2:00 pm
Hey Peter, did you ever get your grainfather?
Posted : 28/01/2015 2:04 pm
If anyone wants one i have one on order due in a couple of weeks that due to time constraints i won't be needing.
Posted : 28/01/2015 2:19 pm
Interested NZCol, sent you a mail
Posted : 28/01/2015 2:24 pm
Clobber, I was waiting for Col's review 🙂
Doh! Col, if clobber doesn't want that grainfather............
Posted : 28/01/2015 2:30 pm
That grainfather looks awesome! Very easy.
I like their kegerator too
Posted : 28/01/2015 3:16 pm
Just bottled my latest batch. American IPA 36 bottles at 6.3% ABV. Should be ready just in time for my 50th anniversary of entering this world. One thing to look forward to I suppose 😕
Posted : 01/02/2015 10:25 pm
Sounds good Johndrummer. Hope it tastes great.
All: So my next step on this wonderful discovery, I have decided is to dry hop.
So I have a brew ready to bottle. it's nothing special, more of a clear out of stuff I had. It's BIAB using the basic massive brewery recipe, but using some crystal malt. So it's 2kg of Maris Otter, 500g of crystal malt. Goldings hops 16 g at 0 minutes and 34g at 55 minutes. Using Safale S-04.
So how do I dry hop it and with what and how much and how long?
I now have phoenix, amorillo, williamette, and goldings at my disposal in a flake style rather than pellet
I usually use decant from primary into a bottling bucket and add a sugar solution in mass rather than per bottle. Do I decant into a bottling bucket, add the hops in a hop bag, wait for a period of time, take the hops out then add the sugar solution etc.
All suggestions really appreciated. I'm guessing Peterfile is out winter climbing!
Posted : 08/02/2015 2:38 pm
Normal practice is to rack it out of the secondary fermenter, once the dry hopping period is finished, into a bottling bucket containing your sugar solution and bottle from there.
It's true that there's very little detritus in the secondary, so I think it would prob be fine to bottle direct, in principle. You would need to take care with adding the sugar solution, though - that would take a very long time to mix thoroughly with the bulk beer just on standing, and trying to stir it in is something to be avoided. So I'd prob prime each bottle individually if I wanted to do this.
Posted : 08/02/2015 2:57 pm
ah. So I could just stick a hop bag into the primary bucket and leave for a period of time (once primary fermentation has finsihed)? Then proceed as normal: racking into the bottling bucket ontop of the sugar solution?
Posted : 08/02/2015 3:08 pm
Think I will go with 40g of Williamette for 3 days.
Does that sound o.k?
Posted : 08/02/2015 3:40 pm
You could do that yeah - dry hopping the primary is a well known technique. Remember to sterilise the hop bag if you're using one.
Depends on what you think of the whole secondary fermenter idea in the first place. Helps to clarify the ale, and is claimed to benefit taste by getting shut of the yeast trub and associated break-down products. Some folk think that's bobbins, though, and never bother with them. Only way to know is to brew it yourself and draw your own conclusios.
Posted : 08/02/2015 3:46 pm
Was at Brew dog's brewery yesterday, very impressive!
Luckily I was working, so now have money to spend on brew gear.
Guys there advised me about plastic pressure kegs, gonna try that put.
Getting a new central heating system next weekend, so emptying a cupboard currently taken up with water tanks so gonna build a brewery in there.
Posted : 08/02/2015 5:15 pm
Page 7 / 9
