Bialetti stovetop q...
[Closed] Bialetti stovetop question - how many spoons?
Just started using my [think it's a 4 or 6 cup] Bialetti again after many years break and it's now my source for all my coffee.
As I like a white coffee during the day I'm putting about 1/3rd cup of milk in the microwave (yeah I know, I use the frother when I feel the need) and giving it a good zap. I then top up the mug with coffee from the Bialetti which I guess is probably about 2 espresso cups worth.
So, how many teaspoons of ground coffee should I be using for two espresso cups?
I'm after a 2 cup Bialetti as well as it's usually only me having a coffee, but for now the big one will have to do.
Posted : 25/11/2010 11:12 am
7g of coffee per shot i think??
Posted : 25/11/2010 11:14 am
[i]Size
The size can be a single, double, or triple, which correspond roughly to a 1, 2, and 3 US fluid ounce (approximately 30, 60 or 90ml) standard ("normale") shot, and use a proportional amount of ground coffee, roughly 7–8, 14–16, and 21–24 grams; correspondingly sized filter baskets are used. The Italian term doppio is often used for a double, with solo and triplo being more rarely used for singles and triples. The single shot is the traditional shot size, being the maximum that could easily be pulled on a lever machine, while the double is the standard shot today.[/i]
Posted : 25/11/2010 11:16 am
I almost fill it up every time. Otherwise the coffee isn't right.
I top up the shots with hot water and a bit of milk - lovely! One on the go right now.
Posted : 25/11/2010 11:17 am
I think mine's an 8-cup and I fill it 2/3 for 2 people. Helpful eh? 😀
Seriously the wee ones are so much quicker, well worth buying, saves time for [s]seeing hot girls and business meetings[/s] internet arguments.
Posted : 25/11/2010 11:21 am
If I don't fill mine to the top it throws a hissy fit and spits coffee out through its valve and the threaded section. It also forces grounds up through the spout.
Posted : 25/11/2010 11:32 am
I have a 3 cup and a 6 cup - the 3 cup= 1 drink for me. The 6 cup = 2 or 3 drinks (but I like a strong milky coffee (with roughly equal milk to coffee)
IME trying to make a smaller amount of coffee then the pot is designed for doesn't really work
so, I think you should buy a smaller pot
Posted : 25/11/2010 11:39 am
I suspect you're right grievoustim. I also think a little 2 cup stove on a camping stove in my office kitchen would be great 🙂
Posted : 25/11/2010 11:47 am
You want one of these:
[url= http://www.bialetti.it/uk/catalogue/scheda.asp?id_cat=31 ][img] http://www.coffeehit.co.uk/getimage.aspx?imageid=232&size=custom&dimensions=275&Product=Bialetti-Electric-Moka-Easy-3-Cup-New-Version [/img][/url]
Andy
Posted : 25/11/2010 12:34 pm
Andy, where can you get those from ?
Posted : 25/11/2010 2:54 pm
One on ebay at the mo...... £40.00 😯 Think I'd rather go with the camping stove 🙂
Posted : 25/11/2010 3:17 pm
Fill it so that its slightly heaped, then when you screw it together it compacts it, thus forcing the water to a higher pressure.
I have a 1 cup, it makes 1.5-2 shots of expresso but I take it off the heat before all the water gets through to make sure no steam does.
Posted : 25/11/2010 3:35 pm
