I want to stir my tea with the best spoon possible. Obviously any spoon will do, but I guess there's a lot of difference in the flavour if it's stirred with the right thing. Right now I'm using a cheapo 10 for £1 jobbie and won't stir tea in front of guests due to the shame.
Any recommendations?
PS It's Punjana, with a tip of a teapsoon of sugar and splash of milk, if that makes a difference.
Has to be the Mustard Rockstirs Flying Tea Guitar Shaped Tea Spoon.
Aye but are ye corrie-dookit?
It's all about technique. Are you stirring it in the right direction? If you're unstirring it you'll never get a satisfactory blend even with the most artisan of spoons.
jobbies are far from ideal when it comes to stirring tea, even if the colour is about right.
OMFG.
Come back when you've grown up and stopped using sugar in tea. And the cheap rubbish for a spoon.. hopeless.. you've got no idea. You're worthless, absolutely worthless.
I use the silver spoon which I was born with 😉
Surely if you're after an artisan stirrer, then it should be something completely inappropriate to be used for the job, so I'd suggest a cat.
A pedigree cat, of course.
Rotate the cup not the spoon for the best results.
I often use the same spoon as I use for my instant coffee. Goes back on my little teaspoon rest after each cuppa
(heathen)
Not just any pedigree, you'll be wanting a heritage breed.
This.
It's 13 times, anticlockwise.
It makes a big difference, you are making a drink for a small child or infant and it really doesn't matter what spoon you use. Tea does not contain either milk or sugar and such infantile practises should not be encouraged. 🙂
Didn't you mean Pedigree Chum? 😆
I think the stirring amounts to about 7 times anti clockwise. That means I'm sub-stirring by around 6, right? Damn. I do put the milk on top of the dry bag first before the water, sometimes WITH the sugar.
Skills course.
Totally transformed my whole tea drinking experience.
Ah, don't get me started on this! As chief tea maker in this house I only use one of the two "proper" teaspoons we have. Everyone else seems to think that the (?) demitasse spoons we have about 5 of will "do" for making tea or coffee and they're about 3ml.
Can't you taste the difference morons?
Anyway, steel, 5ml, doesn't matter a right lot else to answer the OP. O'Neida Metro if you can still find 'em.
Stirring - 12 x clockwise, 9 x widdershins, 6 x clockwise. Perfect for consistent sugar distribution and those little bubbles in the middle of the piping hot still spinning tap water...
You sicken me.
That's not tea, that's warm milky sweetened water.
about 3ml.
6.5ml really brings the tea alive.
Rich_s - MemberAnyway, steel, 5ml, doesn't matter a right lot else to answer the OP
Steel?!
Mild steel? Spring steel? 1.3401? 1.4401? We need ANSWERS!!!
Anyway, I reckon the tea-holding vessel is more important than the stirring device (end of a Bic would do at a push).
Steel?!Mild steel? Spring steel? 1.3401? 1.4401? We need ANSWERS!!!
18/10 obs.
But I have heard that 6al/4v would provide a lighter, more robust taste.
Rich_s - MemberBut I have heard that 6al/4v would provide a lighter, more robust taste.
Whilst damping any stir-induced vibrations, no doubt?! I like it......
A chipped enamelled tin camping mug ftw
You stir your tea with a camping mug?
Spoon for life that....or at least until it cracks
For the purest, smoothest blenderlising, you want to employ the non-invasive Coriolis Stir.
Milk to taste, hold the cup, spin round about 5-7 times, Keep an eye on the tea - for faster spins, you'll have to angle the vessel in towards you to avoid loss.
Stop spinning, watch the magic. You might want to hold on to something so you don't fall over and scald yourself on immaculately-agitated tea.
If you take sugar, you might find this method a little subtle for you, but the rewards of a well executed CS would be wasted on you anyway.
mine arrives to me already stirred.
Otherwise I'll send it back. Not wasting my dunking time stirring the tea.
anticlockwise.
This.
An eCup?
Beginning of the end for tea access issues, you mark my words.
Well, I think it all depends on whether you want to be a STWer and buy something stupidly expensive and kid yourself that it works better and makes your tea nicer (only you will notice this), just because you paid more for it. Or, you want to be sensible with your money, pop into Asda and pay a few pennies for something that'll work just as well, but won't come with the middleclass smugness warranty.
Blag one from waitose cafe in Newton Mearns.
A [url=
[/url]one.
Make sure you use a fresh one for every cup.
Stirring wise I prefer the vertical loop method. Spoon at far away bottom corner, drag forward along the bottom then up the near edge and then across to the back and down to start position. This ensures that the upper echelons of the brew are sufficiently mixed with the lower heavy tones of the flavour . . .
I also like earl grey with milk and 2 sugars !
Don't let the door hit you on the arse on your way out, will you.
