Baselayers
[Closed] Baselayers
For summer riding..
What's good?
Posted : 13/07/2015 7:47 am
to achieve what effect? Tend to only use a normal riding top in Summer (and nice winter days)
Posted : 13/07/2015 7:50 am
Rab Aeon is ultra-lightweight and wicks well. I tend to use them in all weathers as I feel drier. They do long and short sleeved versions.
Posted : 13/07/2015 7:52 am
I still love my Patagonia tops for summer - they do some plain ones and the running ones with zips in.
Posted : 13/07/2015 8:04 am
Don't get sucked into the merino hype - it's expensive, and doesn't wick that well.
Most important thing is that it's skin tight all over.
Posted : 13/07/2015 8:34 am
I like my Berghaus base layers, they cope with my excessive sweating.
Posted : 13/07/2015 8:44 am
Sleeveless offerings from Craft and One Ten
Posted : 13/07/2015 8:57 am
I use whatever's on offer at Go Outdoors. Will I die?
Posted : 13/07/2015 9:05 am
 ton
north face bamboo stuff here. buy 1 get 1 half price.
Posted : 13/07/2015 9:48 am
Agreed... I did several years ago and now have loads of merino that I seldom wear!
Got one of these and quite happy for all of £12!
https://www.alpkit.com/products/koulin-technical-baselayer-top-mens
Posted : 13/07/2015 10:04 am
I use Craft ones and I can generate more body heat that the sun in winter or summer , no smell or staining and they wash and dry well .
Posted : 13/07/2015 10:21 am
For intense efforts and hot days I'd agree that merino isn't ideal, bloody live in the stuff when it's cold though.
When it's hot I have a few of the sleeveless Craft 'string vest' jobbies which work well but I recently got a Pearl Izumi transfer lite that seems to work even better, used it over in the states recently in 39 degree heat and absurd humidity and whilst it wasn't a pretty sight seemed to help hugely in getting the sweat off me.
Posted : 13/07/2015 10:58 am
Endura Trans Rib.
Posted : 13/07/2015 11:00 am
Basic Berghaus tech t-shirts for me. Cheap, light, breathable.
Posted : 13/07/2015 11:01 am
I wear the Decathlon Kipsta stuff in the summer, I think it's their football range. It wicks well, dries quickly and fits very snugly too. And they're well under £10.
For winter usage, the Nike or UnderArmour stuff they sell in Sports Direct is as good as anything.
Posted : 13/07/2015 11:08 am
the Rapha pro team sleeveless base layers are really good for warm weather. the fit and feel are outstanding.
they're not cheap but I managed to get one with a group buy for £36 (20% off if you buy 3).
I also have a Craft sleeveless one which is similar and cheaper but still good.
Merino is for winter.
Posted : 13/07/2015 11:33 am
You know, I've never found a jersey that doesn't sweat where a rucksack touches it, so I'd say that if you use a camelbac or similar "wicking" pretty much goes out the window so you may as well head for comfort, and generally merino is comfier. I generally ride in a Baa Baa.
Posted : 13/07/2015 11:45 am
The standard Base layer shirt from Gore wicks really well. Would definitely recommend http://www.tgstore.co.uk/base-layer-shirt-p-3188.html
Posted : 13/07/2015 3:09 pm
molgrips - Member
Erm, almost my POV too.. Merino is a bit of a "suck and sag" item that I'm moving away from. I have about 6 rapha v neck merino t/baselayers that are really now just worn as t-shirts because in the main they are a bit spongelike. I do wear them if it's cold <10C and sometimes on the top of a manmade mixed one as another layer, but no not really now.
In summer I have a couple of manmade rapha ones and quite a few from the M&S thermal section which are utterly brilliant items and these form the basis of all my baselayers, cheap too.
So, Merino, no not really anymore..
Posted : 13/07/2015 3:25 pm
I also wore the back out of my Icebreaker one after ooh.. five or so winters, where my camelbak sits. Ok so it was a fair bit of riding, but none of the rest of my kit has ever gone through like that.
The £6 reduced base layers from Mountain Warehouse are astonishingly WAY better than the £60 Icebreaker. I was quite surprised acutually - I put one on for the first time and felt instantly cooler as it wicked so well.
Well no, the camelbak only covers a small oblong on your back - the rest of you can still be dry. With merino, you're soggy all over. Warm though, granted - and I did use merino more in cold weather.
Posted : 13/07/2015 3:44 pm
Helly Hansen Dry Fit are fine IMO, never had issues others do with them smelling.
Merino is fine for walking (especially as a mid-layer) and apparently is very good for water sports stuff where it stays warm-ish even when soaked, but for cycling its rubbish.
Merino will draw the moisture away from your skin but then it's no good if there's something acting as a barrier to that moisture escaping - like a jacket.
I find the problem with it is when you stop and it's still wet. Then you get cold.
Posted : 13/07/2015 3:59 pm
dragon - Member
Ahhh yes of course, the "smelly Helly" 😆
#wotapong
Posted : 13/07/2015 4:21 pm
[i]Well no, the camelbak only covers a small oblong on your back - the rest of you can still be dry. With merino, you're soggy all over.[/i]
that's what I said, that the tee will get wet where the rucksack "touches it" I' ve never been "soggy all over" with merino, but we're all different I suppose.
Posted : 13/07/2015 4:24 pm
You may be one of those people who don't sweat a lot.. won't matter much what you wear 🙂
Posted : 13/07/2015 5:09 pm
Yeah, I don't think I am really!
lucky I guess
Posted : 13/07/2015 5:29 pm
Especially when it comes to sunglasses.. I bet you can wear them all ride and not have to wipe.. like my mate Nigel.. jammy sod.
Posted : 13/07/2015 5:31 pm
molly, yeah they steam up a bit in the corners occasionally, but that'll disappear once I start going again.
Posted : 13/07/2015 7:31 pm
Patagonia Merino. Does as advertised ,and lasts longer in the silkweight 1 version with the addition of capilene.
Posted : 13/07/2015 7:44 pm
Cheers all.
I provably should've said I was after the string vest type..
Apologies.
Still, probikekit are doing a deal on Castelli so I'll be getting a boat load of 'em.
Posted : 13/07/2015 11:27 pm
good choice, do the job right and get yourself proper cycling ones they are closer fitting, longer and IME much nicer to wear under a jersey.
Posted : 14/07/2015 5:43 am
