baaaaaad condensati...
[Closed] baaaaaad condensation/ mould - which dehumidifier?
[#3587010]
asked for advice on here and chucked some pictures up a couple of years ago now i think. from your advice it looked like bad condensation. i got a builder in, 2 airbricks in the worst room (our bedroom) and thought thats all i can do really.
since then we've still had black mould on window corners/ sills (in just about all the rooms) and the most confusing thing for me is.... its worse around the air bricks!! i fact its awful. and in the bathroom, the window opens at the top, and theres mould growing on the ceiling now where the air comes in!!
what i dont understand is, why, when we're told ventilations the key, is it worse where the air is?? theres none in the hidden corners, behind wardrobes etc, but really bad where theres air!
its come to a head now when the sparky we got rewiring the house has pointed out hes found out that one of my lads floors soaking. carpets not wet, but the underlay is soaking. stand on it and theres a wet footprint. and mould on the skirting and creeping up the wall.
we've got the water board coming soon to check for leaks, but from what everyones saying is its the old enemy condensation again. obviously the air bricks not made any difference.
house is relatively modern (60s), we open windows regularly, we got air bricks, all i can think of is a powerful dehumidifier next.
wifes seen [url= http://www.meaco.com/proddetail.asp?prod=Meaco20L ]this one[/url]. anyone got any advice on these, or any condensation advice at all? itll prob go in the hall, so wants to look fairly decent as well as able to cope with a house with the humidity of monsoon season in the jungle :-/
thanks
Posted : 20/01/2012 11:54 am
reason it's worse where the air comes in is that it cools the surrounding plaster/brickwork which the water vapour in the air then condenses on so those bits are wetter than everywhere else.
Personally, I can't believe you're getting sodden underlay just through condensation.
If it's as bad as it looks I'd get one of the non-condensing ones in each bedroom as they're quiet and a bigger one in a hallway.
also consider taping clear plastic over a section of floor - if you get condensation on the inside it's damp coming up through, not condensing on it. Get a proper damp survey done...
Posted : 20/01/2012 11:58 am
that much moisture sounds more like a water source inside the house than vapour condensing...
Sounds grim. Sorry not got much I can help with, although if you're near Malvern, I have a dehumidifier I no longer use you can have,
Posted : 20/01/2012 12:01 pm
You are way beyond needing a dehumidifier - you have real problem(s) there. Healthy houses do not have mould, do not have wet patches and do not need dehumidifiers. Air bricks are also not problem solvers in themselves and the behaviour of the occupants, house position, outside environment etc all have a part to play on this sort of thing. That level of mould is seriously unhealthy and can eventually lead to problems for the occupants. As said above, there might be dampness below the house, there might be a leak somewhere - loads of possibles. A dehumidifier would be a sticking plaster on a problem that needs a cure.
Posted : 20/01/2012 12:12 pm
100% agree with this, I attribute my lung problems to damp and mould in a property I lived in.
I'd look at the dehumidifier as being a short term solution to the problem until you can find the root cause, which does sound like water getting in.
Posted : 20/01/2012 12:21 pm
There was an item on the "Rip off Britain" TV programme this week where a woman had her home "cavity insulated" and it was caused almost this level of problem. She was having to open doors and windows just to get enough airflow.
Posted : 20/01/2012 12:25 pm
are the rooms with the damp on the first floor?
Posted : 20/01/2012 12:29 pm
Interesting. I'd be quite interested in knowing how the cavity wall insulation can do this. Does it explain this point in the prog? (Not sure that I want to waste 30 mins of my life).
Posted : 20/01/2012 12:31 pm
Well you might as well rip up the carpet and underlay as its sodden anyway, that will remove a large stored amount of water. This might then help trace the source of the leak (as it does sound like a leak)
Posted : 20/01/2012 12:36 pm
I guess the simple answer is similar to the rule about not pushing insulation right into the eaves in your loft as it stops airflow. The cavities must perform a degree of ventilation and blocking them up (same as blocking up fireplaces etc) could be a contributing factor with damp issues.
Posted : 20/01/2012 12:43 pm
 irc
I bought a house once where the previous owner had tried to cope with damp by repapering after covering the wall plaster in one area with a rubber solution. The wet wall was directly inside the place where a flat roofed porch was which was a red herring. I eventually found the cause of the damp to be that someone had replaced a floorboard after doing work at a radiator and had put a nail through a pipe causing a slow but ongoing leak.
If you can narrow the damp problem to one area then inspecting the central heating piping is worth doing. It's a big job but you have a big problem.
Posted : 20/01/2012 12:45 pm
ds - moisture that would have traversed the gap in the cavity, then, condensed on the inside of the outer wall layer and been removed through ventilation was now condensing on the inside of the inner wall layer.
Posted : 20/01/2012 12:47 pm
Unless it's a poky place and you cook loads on the hob with no lids and constantly have clothes drying, I'd be looking for a leak.
Just watched the prog and it talks about the lack of designed ventilation and that the cavity wall insulation only highlighted an existing problem of poor house design. So clearly any isulation that is going to block or prevent the building from breathing is going to cause problems, but somehow I don't think this is the OP's problem.
[url= http://arch.ced.berkeley.edu/vitalsigns/res/downloads/rp/airflow/HEER1-BG.PDF ]Something on airflow in buildings.[/url]
Posted : 20/01/2012 12:52 pm
 will
I'll be following this with interest. i have a similar problem, and the landlord is being less than helpful...
I'll put soem pics up later if thats cool with the OP.
Posted : 20/01/2012 1:04 pm
I have used a dehumidifier for a lot of years during the winter months and they do a terrific job. The one i use is an ebac 2580. It also drys the washing at the same time.
http://www.ebacdirect.com/product.php?productid=28&gclid=CLmh87HJ3q0CFcshtAodzzWNdw
Posted : 20/01/2012 1:13 pm
Stoner YGM
Posted : 20/01/2012 1:32 pm
you have damp walls because you have cold walls.
the warmish air in your house carries lots of moisture - this condenses on the cold walls.
more so where the walls are coldest.
i guess:
you have no insulation in your walls.
and, your house has been plastered with modern plaster - this stuff doesn't breathe.
i could well be wrong, but if so, you either need to insulate, or replaster with something breathable.
does sound like a leak...
what floor is it on? (ground level, 1st floor, etc.)
Posted : 20/01/2012 2:52 pm
just a bit of an update. just had water board round who confirm theres no leak, and its pretty certain its condensation. also spoke to 'peter cox' who are experts in damp, who also say theyre sure its condensation. (although they havent seen it)
just to answer a couple of questions, its the ground floor, the insulation leaves a bit of air to circulate. it also has cavity wall insulation. it was my parents hous, and my dad had it put in in the seventies. there were 5 in the house then with no problems, against 4 of us now, so im just still astounded it can be this bad when it never has been before.
will, of course i dont mind you posting pics. id be interested to see them and compare against my problem.
i spose i got to concentrate on the condensation solution now. i know dehumidifiers may be a sticking plaster, but talking to some others, theyve reduced their problem with them so i dont have much else i can do.
so the original question remains....... any recommendations? is the one in my first post about as good as i can get for the money?
thanks a lot
Posted : 20/01/2012 5:10 pm
Useful reading before you buy a dehumidifier:
http://www.airandwatercentre.com/blog/119/desiccant-or-compressor-driven-dehumidifier/
Posted : 20/01/2012 5:23 pm
Ebac - we live in an ancient house which suffers badly from damp/condensation and we use an ebac unit through the winter which has almost stopped the damp. That plus religious wiping of window sills before bed!
Posted : 20/01/2012 5:24 pm
[i]just to answer a couple of questions, its the ground floor, the insulation leaves a bit of air to circulate. it also has cavity wall insulation. it was my parents hous, and my dad had it put in in the seventies. there were 5 in the house then with no problems, against 4 of us now, so im just still astounded it can be this bad when it never has been before[/i]
So you have to ask yourself what's changed structurally between then and now, and especially in the twelve or so months up to the point at which you started noticing problms.
Posted : 20/01/2012 5:32 pm
thanks cougar, just reading that now.
absolutely nothing 🙂
Posted : 20/01/2012 5:34 pm
We have condensation problems, though not to the same extent that you do. We were getting light mould build up on the bedroom windows, and lots of condensation on the inside of the windows and window recess (so much so that when I painted the paint ran off the walls). I bought a dehumidifier (ebac 2850 one linked above) about 2 months ago and a temp/humidity monitor. So far things appear to have improved. Previously on cold mornings there was very noticeable condensation on the windows and the recess walls were damn. Now we are getting only very minor condensation at the very bottom of the glass. The walls appear to be drying out nicely. At around the same time we also started closing the bathroom door after showers and leaving the window open in there for longer (allowing more of the post shower moisture to escape out the window).
Ideally I don't want to have the dehumidifier, however there does not appear to be another solution in this house (other than a house wide heat exchange ventilation system).
Posted : 20/01/2012 5:46 pm
Sounds like a plumbing leak to me. Is the ground floor solid (concrete) or suspended (timber)? If solid are there heating or other pipes bedded in it? If so they could have corroded, started leaking and be soaking the floor. Moisture will then evaporate from the floor and condense in the coldest parts of your house. If it is suspended are there airbricks below floor level outside and are they free-flowing? They are there to help dispel moisture under the house. If the floor is suspended find a way into it (take up a floorboard) to see if there is water underneath.Be very wary of damp-proofing "experts": they have a vested interest in selling you a damp-proofing system which may not be appropriate to your problem.
Take a look at you lifestyle: lots of boiling, drying clothes indoors, tumble-drying without an external outlet, baths, leaving the bathroom door open after a shower of bath, using a portable "Calor Gas" type heaters all produce large amounts of water vapour which will form condensation on cold surfaces.
Yes, you need ventilation but you need heating too.
I still think it's a plumbing leak. If you are anywhere near South Buckinghamshire I could take a look for you.
theres no leak. been confirmed by anglian water. the floors concrete with tiles on top. cant say for sure where the pipes are 🙂 i spose they must be embedded some way, but ive never been told and theres nothing obvious.
as far as dehumidifiers go, i spose theres got to be a fine line between getting rid of excess moisture and waking up in the morning all wrinkled up and unable to speak 😀
ta
Posted : 20/01/2012 6:09 pm
Anglian will presumably have just checked the water main? Even if they went further it is extremely difficult to identify whether a pipe buried in a concrete floor is leaking, especially with tiles on top. Have a look to see whether the radiator pipes drop into the floor.
Posted : 20/01/2012 6:16 pm
radiator pipes come from the loft. but im not sure where they start. think its all done from roof void tho.
im guessing a good measure of whether any pipes are leaking is if the water meter dial goes round when everythings switched off. which it doesnt 🙂
thanks
Posted : 20/01/2012 8:04 pm
Condensation is a result of different air temperatures. What temperature do you have the central heating set to?
If the walls are insulated, what is the state of roof insulation? It packs down after a while and could do with being checked?
Could indeed be rising damp too. A break in the damp proof course or the membrane beneath the concrete floor - a moisture meter will narrow that down for you.
If I may suggest, before splashing out on some sticking plasters in the form of de-humidifiers, get a couple of specialist opinions - there are bound to be some local historical building surveyors and make sure they are historical buildings peeps, or get a damp-proofing firm or two to come round and check - bearing in mind their ulteria motives. Both should check with their pointy moisture meters.
Hope that helps.
Posted : 20/01/2012 9:58 pm
Nope. It doesn't take much of a steady drip to cause water problems and it could be a cistern / central heating pipe / lots of other things. Anglian wouldn't check your plumbing beyond where it enters the house I guess and not a CH system.
If it didn't used to happen in the house and it does now, something has changed. Whether that is something that is part of the house or the behaviour of the occupants, something is causing it and needs fixing. If it damages the house structurally in the long term you have a massive problem to deal with.
Posted : 20/01/2012 10:01 pm
Fit a slow running xpelair fan, to an outside wall, witha humistat, also find the stiop tap, and turn all taps off, put a screwfdiver to the stoptap, and put your ear to the screwdriver and listen for wooshing or water noise, if you can hear someting you have a leak.
ear to the handle of the screwdiver, or you may do yourself an injury.
Posted : 20/01/2012 10:16 pm
Sounds way too much for condensation. Does the situation change with the seasons?
Posted : 20/01/2012 10:45 pm
We had it real bad in the bathroom and bedrooms, got a [url= http://www.amazon.co.uk/Prem-I-Air-PMDN-12DMN3-Litre-Compressor-Dehumidifier/dp/B002W4Q6SM/ref=sr_1_37?s=kitchen&ie=UTF8&qid=1327096015&sr=1-37 ]compressor one[/url] and it filled up with water but that never solved the problem. And open windows don't help either.
What we did in order of effectiveness:
The [url= http://www.tlc-direct.co.uk/Technical/Ventilation/Ventilation4.html ]correct [/url]bathroom (shower) extractor fan and keeping the door shut.
A low watt electric radiator on a timer in the bathroom.
Wickes anti-mould [url= http://www.wickes.co.uk/invt/214284 ]paint[/url].
Keeping the kitchen door shut, windows open when cooking or the dryer is on.
Wiping down the inside of the windows in the morning.
Dehumidifier
Opening windows an hour a day.
Train the children to put towels in the freakin washing basket.
Edit - reckon there was a leak in the bath overflow too sometimes its hard to tell, replaced the pipes anyway.
Posted : 20/01/2012 11:02 pm
As above, there's no way that you should have sodden carpets from condensation only.
We had mould problems in a 60's 2 bed double glazed ground floor flat we rented a few years ago. There's only so much you want to have the windows open during mid winter. A dehumidifer helped a bit, but what pretty much solved the problem overnight was the addition of a good sized airbrick (about the size of 2 standard bricks) in each of the rooms with external walls - one in the living room and the dining room at one side of the flat and another in our bedroom at the other side - therefore allowing a flow of air all the way through the property. Getting a condensing tumble dryer rather than drying clothes in the flat during winter also made a massive difference.
As you seem to have the ventilation side nailed, I'd say there has to be water getting in somewhere. Warm air rises - so why would it condense to that extent on the carpet? Cold floor tiles perhaps.
Posted : 20/01/2012 11:57 pm
First thing is to get rid of the carpet and underlay. If its that wet then you need it out before doing anything. It will immediately improve the air quality in the room. We managed to wreck a mattress by drying washing nearby as it acted as a giant sponge - once it was out the house we then address the excess moisture in the house that was causing bad mould on the ground floor windows. We got an ebac full on dehumidifier and it solved our problem. To be fair it was partly created by us drying so much washing but that seems hand in hand with a baby.
Ebac was fairly expensive but very well designed and earned its price in improved air quality and much easier heating. Mould has disappeared. It is designed to leave on all the time, which works well for us and was important as MrGinger worries about leaving things plugged in/running in terms of potential fire hazards. I would definitely recommend the brand.
I sympathise with what you are going through. I found it such a general source of a worry but getting the water out the atmosphere, although only treating the result not cause, just took away the anxiety and stress. I couldn't believe the difference. Can't believe how long it took for us to do this though.
Posted : 21/01/2012 12:25 am
about 60 degrees, maybe 61. not on all the time as thatd cost too much. so often on during the evening, off in the daytime and beddybyes time.
i put the insulation in myself a couple of years ago. probably not as thick as regulations suggest, but its still a good thickness. and ive left gaps around the edges.
everyone we've rang so far wants around £100 just to look. i dont mind spending that towards a cure, but im loathe to spend it on someone coming round just to say "yep, thats condensation mate"
good point, altho as i said, all the pipework seems to be in the loft, and theres no sign of any damp or mould up high. plus, where the worst patches are (around air bricks and against a couple of walls), theres no radiators/ pipes at all.
matey did something along those lines. put a long bar with a wooden handle in the water meter against something, held it to his ear and said its fine.
yes. definitely better in summer. windows open all the time, warm air, we dont have a problem then. at least...... i dont think so. i spose i havent upturned carpets to check, but the steamy windows etc arent a problem in the summer months.
The correct bathroom (shower) extractor fan and keeping the door shut.
just getting our sparky to upgrade ours now, and we'll make sure the bathroom door is always shut. ive knocked the radiator off in there so we're not wasting money on heat flying out of the open window. this may be contributing to the problem, as we havent really done this so far. bath waters maybe in for best part of an hour at a time, and sometimes the door left open. we're going to rectify this.
small bathroom, a GCH radiator in there, but are you suggesting we heat the room and open window at the same time??
kitchen door is rarely shut, windows open a fair bit f we're cooking somethings a bit steamy 🙂 dryer is a condenser jobby.
at first i would definitely have agreed with you, but the damp firms on the phone are saying yep, thats normal, seen loads, and so is the builder. theyre all 100% sure its condensation.
our floor will be cold yes. its not wood, its concrete covered by tiles, altho theres underlay and carpet covering them.
yep, we'll have to change all that. we're in the middle of rewiring and an extension being built, so therres a fair bit of mess for the next month. after that we'll change the carpets.
we've ordered a dehumidifier now. i realise it may not solve the problem, but as has been advised above, itll certainly help take some moisture away. im thinking if we leave it on in the day, in the hallway, and leave all doors open, this may help.
thanks a lot for all the advice, and please, keep it coming if youve any more 🙂
cheers
Posted : 21/01/2012 9:58 am
Near in mind that if it is condensation then you're best of running it whilst there's people in the house as that will be when most of the moisture will be generated.
Posted : 21/01/2012 10:39 am
You have a builder in doing extension yes ?
Whats his opinion ?
Posted : 21/01/2012 11:24 am
yep, the builder says its condensation, and hes seen it plenty of times.
Posted : 21/01/2012 12:07 pm
We used to do this, ended up buying a dehumidifier because we didn't realise how much trouble it caused. Were without the bath for a month in winter whilst I slowly redecorated (good test of a marriage, whether your wife puts up with washing in the kitchen for a month in winter) and the damp vanished ! As you might imagine, we don't leave bathwater lying around now.
Also, condenser tumble driers aren't as efficient as you might think. We got the one Which recommended and, using a hygrometer to measure it, the house humidity rises by nearly 10% when it's in use, and stays elevated for a couple of hours.
Posted : 21/01/2012 12:39 pm
That's true, ideally you'd have a conventional one vented to the outside. It's certainly going to make a massive difference over leaving clothes drying in the house or on radiators though, as 100% of that moisture would be going into the atmosphere inside the house.
Posted : 21/01/2012 3:36 pm
Wonder if the cavity wall insulation is bridging and transferring moisture from the cavity to the interior walls of the house.
I have read about this happening with cavity wall insulation,possibility?
Posted : 21/01/2012 10:40 pm
Need to see some pics. Internally and on the external wall.
The wet carpet is not helping at all but trying to understand how the carpet got so wet is a struggle. (The RH must be off the scale)
The extent of the moisture, is it localised or generally over all the external walls. Are any internal walls affected? Is it worse or better depending on the orientation of the rooms? Whats the use of the affected rooms? Whats the extent of the wet carpets? What the situation and detailing for the extension where it attaches to the house? Do you have a internal swimming pool, sauna or wet room???
Water can breach the cavity but it's dependent on numerous factors, exposure and orientation being two.
Posted : 22/01/2012 12:31 am
sorry, no pics as we've bleached the walls to clean em up. unless i can dig out the old photos from a couple of years back, as its the same problem.
just to answer your questions, the moisture and mould is sort of localised. basically against one wall (north facing) in our bedroom, and in one corner of our lads bedroom (east facing). the wet underlay is maybe only wet for a foot or so nearest the wall? and theres no sign of anything on the external walls. all the brickwork/ pointing looks fine. extension is other side of house. no swimming pools, saunas etc, not that rich 😀
as i said, thats the situation for the wet carpets, but id say just about all our windows collect mould in the corners.
we've resigned ourselves to the fact that its condensation now, so we're going to try and change the way we 'operate' in the house to see if it gets better.
once the extension is finished (months time hopefully), we'll replace carpets, give the windows and sills a good clean, and see if it returns.
bathroom door will be closed all the time, window open as much as poss. extractor fan in there. kitchen door closed when cooking. windows open as much as poss (although we do that anyway).
did forget to also mention how bad it is in our porchway, although thats probably irrelevant to bathroom etc. we have a small porch off the back door, which has our boiler and washing machine. its a single skinned wall with felt roof. vents to outside obviously as theres a boiler in there. and its awful in there!!! plaster and internal brickwork covered in mould and door dripping wet most of the time. we clean it up every now and then, but cant realy get behid washer, and its just embarrassing really. we've been told a proper roof and insulation may help, and we may have a word with the builder about this.
thanks for your advice.
Posted : 22/01/2012 9:58 am
You mentioned cavity wall insulation in the 70's. I don't know what they used back then, but I wonder if its worth checking if its still in place, or has slumped to the bottom of the cavity, leaving a sodden pile that bridges the cavity.
Posted : 22/01/2012 10:43 pm
