AutoCAD 2009 & ...
[Closed] AutoCAD 2009 & CADS RC HELP PLEASE!!!!!!!!!
Got AutoCAD 2009 installed on my computer along with CADS RC.
I can't get on with the new style of AutoCAD so do my drawing in Classic workspace but as I can't get the CADS RC menu to be added to the menubar at the top in Classic I have to switch to CADS RC workspace, however when i switch back to Classic my toolbars have all gone and they are back to the default bars even though I have locked the toolbars. How can I stop this happening? Or even better, How can i get CADS RC menu to appear in the menubar in Classic Workspace?
Its getting very frustratic at the moment.
Thanks a lot
Posted : 11/01/2010 1:52 pm
I'm by no means sure as all the AutoCAD systems I have worked on are set up and I just plough on with the drawings, but have you set up your templates as in A4, A3 .... A0 paper spaces and saved them?
Posted : 11/01/2010 2:13 pm
 Haze
Have you got the CADS RC menu in *.mnc or *.mns format?
Posted : 11/01/2010 2:19 pm
Try the following: Tools - Load Application, then load the RC menu file. If this works you will need to do this every time you start CAD. There is a LISP routine that will load it automatically, but I don't have a copy of it. To get your Classic toolbars to load every time, save it in you're Profile once you have got it set up as you want. (Tools - Options - Profiles).
Posted : 11/01/2010 2:30 pm
Haze - i've no idea what that means or even how i have it. how can i find out and what difference does it make?
Posted : 11/01/2010 2:42 pm
 Haze
If you want to load a custom menu into AutoCAD for use as a pull down, you need to have the file containing all the settings - it will have the file extension mns, mnc, mnu or similar.
You can then load this into AutoCAD from tools > customise > menus
I'm going off memory and possibly off an older release, but it should be something similar to this.
Posted : 11/01/2010 2:51 pm
