Audiophiles of STW ...
[Closed] Audiophiles of STW rejoice
El Reg are reporting the advancement of audio technology with these directional ethernet cables costed at a mere $10,000.00.
[url= http://www.theregister.co.uk/2015/02/09/perfect_your_mp3_listening_pleasure_with_this_bonkers_ethernet_cable/ ]$10,000 Ethernet cable promises BONKERS MP3 audio experience[/url]
Posted : 09/02/2015 12:13 pm
Well, Mr Christian Andersen will be loving that ๐Ÿ˜‰
Posted : 09/02/2015 12:29 pm
I must rush out and buy a NAS based system just so I can use these.
Posted : 09/02/2015 12:30 pm
Fairy tales indeed. You'd think we might have a hang of this technology thing.
I'll need to get some better MP3s - or perhaps there's a record player I can stream from.
Posted : 09/02/2015 12:36 pm
That's amazing. You'll need to make sure you've got the right drives in your NAS to take full advantage though. http://singletrackworld.com/forum/topic/hifi-breakthrough
Posted : 09/02/2015 12:47 pm
I'm sure I read they work better when its all aligned with ley lines.
Fools and their money. Etc.
Posted : 09/02/2015 1:56 pm
I quite like the idea of [b]homeopathic hi-fi[/b].
It works because you think it does.
Posted : 09/02/2015 1:58 pm
Wow!
It probably an elaborate joke by Audio Quest. They made one for the photo and stuck it on their price list. Bunged What Hi-Fi and few quid and asked them to say it has "Breathtaking openess and clarity" and give it five stars.
Helps them sell their cheaper - but still pointless - digital cables
Posted : 09/02/2015 2:15 pm
Does it come with winged unicorns who hold it on their horns while hovering off the ground, to avoid unwarranted static interference?
I need to know before I shell out...
Posted : 09/02/2015 11:41 pm
BAAAAAAAMP
Actual testing to be done in short order by Ars Technica and the James Randi Foundation ๐Ÿ˜€
http://arstechnica.co.uk/gadgets/2015/07/ars-prepares-to-put-audiophile-ethernet-cables-to-the-test-in-las-vegas/
This will not be popular with the manufacturers.
Posted : 17/07/2015 8:11 am
There's a bit in there about audiophile objections :
"If you want to know what you enjoy listening to, there's no better way than to listen over time."
I think there might be some truth in that, so the test should involve one period where the reviewer is using one cable, then a similar period using the other cable - at which point they should be familiar with what they perceive/imagine are the differences between the cables, then do the dbt with the choice of music that they want as they think that it is more likely to expose any differences.
No one can complain about that.
As a bloke I find I can focus on one area of sound, whereas my wife will hear the big picture and may identify any differences more readily. Listening for a period of time might expose the listener to the big picture more.
Posted : 17/07/2015 12:17 pm
I hear that Neil Young is their first customer.
Posted : 17/07/2015 12:29 pm
I'm sure we're all just jealous that we haven't come up with ways to make fools part with their money... I know I am.
Posted : 17/07/2015 1:15 pm
Well, it's certainly one of my regrets that I lack the imagination and drive to come up with such startling innovations and the ability to sell them and make huge amounts of money in the process.
Posted : 17/07/2015 6:49 pm
Interesting thoughts, Mr turnerguy.
I think I switch between the macro and the micro ๐Ÿ˜€ I was trying to listen to Dan Hartman's Relight my Fire on YouTube, and it was just lifeless.
Fire up the Vinyl, much better [and my non-audiophile friend agrees].
Listening to Random Access Memories, I like to focus on the intonation on the drumming, cymbals and guitars. Oh and the beautiful synth basslines and beats.
I think I might stick it back on ๐Ÿ™‚
[not via ethernet]
Posted : 17/07/2015 7:14 pm
So the high frequencies travel along the outer silver "skin" not the copper core? High frequencies? In the digital domain?
Posted : 23/07/2015 2:01 pm
skin effect is well known - I think the higher the frequency the more the signal will want to travel on the outsides of the cable, so more so for digital.
Posted : 23/07/2015 2:07 pm
Oh come on. It's 1s and 0s.
Posted : 23/07/2015 3:03 pm
what does a 1 and a 0 look like when on the cable then ???
Posted : 23/07/2015 3:21 pm
But it's Cat 7 which is moar betterer than Cat 6A.
Oh, hang on what's the plug spec again?
๐Ÿ™„
Posted : 23/07/2015 3:28 pm
I give up. Do the 1s travel along the silver and the 0s along the copper or vice versa?
Posted : 23/07/2015 3:47 pm
Well, he's kinda got a point, but at the same time, the signal is either there at the other end or it isn't - the system just isn't that sensitive.
Can't say I've had any trouble with normal ethernet cable ๐Ÿ˜€
Posted : 23/07/2015 3:59 pm
It's nothing to do with sensitivity and everything to do with applying analogue thinking to digital connections.
Like you said in the first sentence, the signal is either intact or it isn't. If the signal is correct, it's a nonsensical concept to suggest a better cable will make it more correct.
Posted : 23/07/2015 4:06 pm
I mean that the system is able to resolve the data even if there is a degree of noise.
Posted : 23/07/2015 4:12 pm
surely better to use aiff or wav since storage is sooooo cheap now?. i've just started re-importing library using wav so will work in car as well as home network quality much better all round.
Posted : 23/07/2015 4:13 pm
the switching between 1 and 0 still happens at a high frequency though, so surely subject to skin effect?
not saying the silver has any effect though, or that the skin effect is significant.
I've half a memory that it wouldn't really apply for such thin cable, it's more relevant to high tension supplies and suchlike; but TBH we're outside of my electrical comfort zone here, I honestly don't know.
Posted : 23/07/2015 4:47 pm
TurnerGuy - Member
Struggling to see how 'skin effect' can have any bearing on how a digital signal travels along the cable. It has no high or low frequencies until it passes through the DAC at either end; between them it's one continuous stream of 48- or 96-bit numbers, only the DAC can influence those numbers by how accurately it converts the digital stream back into analog.
IANAE, but those claims just seem bogus.
Posted : 23/07/2015 8:04 pm
Of course it's bogus.
Say the data is "36."
In the analogue world, susceptible to noise and degradation and a million other things, it's an exercise in Chinese Whispers. Unless you use high quality cables the data could come out of the other end as 35, or as 36 and 5 at the same time, or 'herby bricks.' This is what you're fighting against and why you pay good money for interconnects.
In the digital world, the result is 36 or it's no result. The tech has the ability to go "gurdy pricks, what, say that again?"(*) but ultimately the 1/0 concept results in "it's perfect" or "it's buggered." There is no 0.9.
It's like suggesting that you could download a game and then find that because of a low quality connection all the mountains are pink or your car is a banana. It's just not possible.
(* - oversimplification.)
Posted : 23/07/2015 8:37 pm
Not the best example, you could download a part of a game and have a single-bit error that goes unnoticed 'till later, grrrrrrr.
Posted : 23/07/2015 8:59 pm
You could theoretically if you didn't CRC check the download. (And it still wouldn't give you lower fidelity graphics, it just wouldn't work or crash.)
Posted : 23/07/2015 9:04 pm
OK man, it just reminded me of wasting a lot of time yesterday!
Posted : 23/07/2015 9:09 pm
Should've used the download manager. (-:
Posted : 23/07/2015 9:13 pm
Here is my sound improving tip which is guaranteed to work:
* take your favorite CD and pause it ready to play.
* now take the index finger of your left hand and jam it tightly in your left ear
* play the CD
* after a while take the finger out of your ear, you will find the sound and soundstaging improves considerably.
I have tried this in demonstrations to many audiophiles and it works every time for the majority of listeners, only those deaf in their left ear tell me it does nothing for them.
Posted : 27/07/2015 11:36 am
The results of the Randi/ars test are in:
[url= http://arstechnica.com/gadgets/2015/07/even-vegas-strangers-agree-340-audiophile-cables-make-no-difference/ ]meh[/url]
Posted : 31/07/2015 12:32 am
I would count as a skeptic but I don't really like that the tests were performed with headphones only.
I would have also had had two identical computers and switched the analog paths to the headphones, so I didn't have to mess around changing the digital cables and introducing delays - audio memory is pretty short and those delays are of longer duration.
Posted : 31/07/2015 8:57 am
The problem with that is,
Yes, in the real world buying two identical test rigs would be trivial. However, in the fantasy world inhabited by people who sell - and buy - $300 Ethernet cables in the mistaken belief that they can improve the quality of digital audio encapsulated in Ethernet frames, building two [i]identical [/i]test rigs would be nigh on impossible.
Ie, when the results came out that there was no difference, they'd claim that the 'premium' test rig must've been inferior in some way.
Posted : 31/07/2015 9:08 am
Headphones are good choice because they take the room out of the equation.
Regarding audio memory; if the listener cant spot a difference because of a couple of minutes delay then I'd politely suggest any difference that may be present ain't worth worrying about!
Posted : 31/07/2015 9:13 am
TurnerGuy - Member
An easier way would be to set the output of the playback software to be a disk writer, play the file back through both the cables, then ABX the resulting WAVs from local disk. They'd be bit-for-bit identical anyway, so it's a waste of time but there we go.
Guess they'd be back to saying the electromagnetic noise from the error correction on the ethernet cards could affect the DAC then though ...
Posted : 31/07/2015 9:28 am
meh
Did they really need to go to such lengths to prove something that was ****ing obvious to anyone with an iota of common sense?
Posted : 31/07/2015 9:32 am
I'm not saying it's necessary or would even work, but isn't the point of the shielded cables that they stop interference getting into the machine at all, not necessarily just into the DAC? In the Chinese whispers analogy it'd be like getting the right answer from the penultimate person in the chain, then getting punched in the face (by some randomly induced current where your Ethernet cable coiled around the power cable).
Full disclosure, I have moderately expensive but very unequal length speaker cables.
Posted : 31/07/2015 9:56 am
meh
Did they really need to go to such lengths to prove something that was **** obvious to anyone with an iota of common sense?
Welcome to the scientific method. For many of us, this is what we do every day.
Posted : 31/07/2015 10:15 am
[i]For many of us, this is what we do every day.[/i]
I also have a pointless job ๐Ÿ˜‰
Posted : 31/07/2015 10:28 am
Such as like the world being flat you mean.
Posted : 31/07/2015 10:30 am
DezB - Member
I at least get to use a massive magnet to look inside people. That bit is fun.
Posted : 31/07/2015 10:33 am
[i]Such as like the world being flat you mean.[/i]
Er, yeah, exactly the same as that. You know what this thread is about, yeah?
Or you just jumped in at the end with something totally irrelevant?
Posted : 31/07/2015 11:11 am
This is what I was thinking, just can't understand why people would even think there could be any truth in it, but then billions of people still believe the world was created by an invisible spirit in six days or something.
Posted : 31/07/2015 11:21 am
Human nature innit?
You have to keep proving things to keep the light of rationality burning.
It wards off our tendency to willngly believe nonsense.
Posted : 31/07/2015 11:35 am
It's not an experiment I would have thought worthwhile, but on the other hand just relying on "common sense" is about as far from the scientific method as you can get.
Posted : 31/07/2015 11:44 am
thing is it doesn't need to get to the common sense stage, the science of digital data rules out any possibility of there being a difference before ears can be involved.
Posted : 31/07/2015 11:57 am
Well, the article was about the proof or otherwise of a theory that an ethernet cable carrying digital pcm information makes a difference to the final sound quality.
The point is that people think something as accepted wisdom and someone questions that, so it is necessary to investigate using a scientific method which is actually true.
If the experiment proved positive, then it would query the accepted wisdom of digital information. That is the point, I'm sorry you cannot see the point. ๐Ÿ™„
Posted : 31/07/2015 12:07 pm
And hence my comment about the flat earth. The science at the time said it would be stupid. If enough people observe something then it's worth investigating. If it's proved then the current science needs amending.
Posted : 31/07/2015 12:10 pm
They are in a great big hall so the room isn't as much of a factor as it would be in a smaller space, plus the effect of the room would be the same for each person - the only advantage would be that you wouldn't have to worry about them moving around on their seat and therefore moving their head/ears around - unless they adjusted their headphones during the test.
By using headphones you are taking other things - like the 'image' or 'soundstage' out of the equation as well.
Posted : 31/07/2015 12:22 pm
Well done on convincing yourself that your comment was worthwhile traildog. The rolly eyes helped a lot.
[i]And hence my comment about the flat earth. The science at the time said it would be stupid. If enough people observe something then it's worth investigating. If it's proved then the current science needs amending.[/i]
Brilliant ๐Ÿ˜†
Posted : 31/07/2015 1:16 pm
You should get a hifi marketing job! But seriously, digital data can't be observed 'differently', read the analogy on the first page or google for more info.
Posted : 31/07/2015 2:14 pm
Love how a 'flat earth' reference has unwittingly made it into this thread!
Posted : 31/07/2015 2:34 pm
That's not correct. Digital information is actually in an analogue domain.
https://en.wikipedia.org/wiki/Jitter
However, I'm not saying the Ethernet cable will make any difference. All I am saying that it is not daft to scientifically investigate claimed observations, despite what DezB says.
Posted : 31/07/2015 3:37 pm
I don't understand why it was even necessary to do listening tests. All that is needed is to compare the ability of each cable to accurately transmit the digital data, the analogue bit has nothing to do with it. But we all know that's not a test worth doing.
Posted : 31/07/2015 7:40 pm
