Anyway to re-invigo...
[Closed] Anyway to re-invigorate a Ni-Mh battery?
I have a Ni-Mh battery (36v 9ah) which won't take/hold any charge. Before O have to blow £500 on a replacement, is there any way to bring it back to life?
According to YouTube I stick it in the freezer for 24 hours, let it defrost and then charge it. Will this work?
If not, what will?
Posted : 25/10/2012 12:34 pm
What can you lose by trying?
Posted : 25/10/2012 12:39 pm
Lots of good stuff about batteries here:
http://batteryuniversity.com/learn/article/Nickel_based_batteries
(no idea if it covers the freezer method or not. I'll leave that to you)
Posted : 25/10/2012 12:41 pm
Talk to smudge he is branching out into Ebike replacement battery packs
Posted : 25/10/2012 12:50 pm
recellyourbattery.com
Posted : 25/10/2012 3:37 pm
It should be good for around 500 cycles if the charger has been kind to it. If you think it is anywhere near that there is nothing you can do short of putting new cells in it. If it's gone wrong for some other reason then you might be able to squeeze some life out it by forcing it to take a charge but you'll need a variable power supply with current and voltage control. You should be able to get some new cells for a lot less than £500
Posted : 25/10/2012 3:43 pm
Niagra?
Posted : 25/10/2012 3:51 pm
