Any tilers in the h...
[Closed] Any tilers in the house?
I've decided to re-tile my bathroom and need a cutter. Please could you recommend me a decent manual tile cutter? I've around £100 to spend but happy to stretch that a little if needed?
Thanks in advance
Dave
Posted : 28/12/2019 7:41 pm
The budget will depend on the size of tiles to be cut really.
Any tile cutter by Sigma or Rubi would probably be your best bet and I'd rather have a second hand decent example of one of those than a not so great new one. Even if it was a bit tired looking you'd only need a new wheel to cut like new anyway.
Posted : 28/12/2019 7:54 pm
 DT78
screwfix big clinker.
Posted : 28/12/2019 8:07 pm
What type of tile, what size and what orientation of installation?
Posted : 28/12/2019 8:16 pm
As above. a used Sigma or Rubi is a good shout and will sell for the same amount as you buy it for. You could also need a diamond blade on a grinder for certain cuts, I use ATS 115mm diamond, don't buy eBay specials.
Posted : 28/12/2019 8:22 pm
I use a Rubi best cutter iv ever used also have a cheap electric water cooled one for tricky bits
Posted : 28/12/2019 8:24 pm
As above....you’ll definitely need a cheap wet cutter too from Toolstation or the likes.
Posted : 28/12/2019 9:25 pm
Thanks all. Looking at 400mm ish tiles. Will go for that £95 Rubi one.
Posted : 28/12/2019 9:46 pm
Take a look at the tilers forum. Manual cutters are only really suited to ceramic tiles. For porcelain tiles you need diamond blades. Rubi make a good one for a 4” grinder.
Posted : 29/12/2019 12:10 am
Not really Wharfdale. I make a lot of my living by tiling, from apprenticeship 25 years ago and I hardly ever use a wet cutter these days. I mostly use a Rubi TX90 and a grinder with diamond blade and dust extraction, also another with a polishing disc. The wet cutter only comes out for stone jobs really as it’s messy, slow and time consuming to set up.
Posted : 29/12/2019 9:46 am
as above a decent manual cutter is fine for porcelain, think mine is the rubi TX700 which has done me for quite a few years but now could do with a bigger one. bit out of the OP's price range though. still use my wet saw quite a bit as i find it gives a nicer cut and is much easier to get a perfect straight cut than the grinder. will only set it up if i know its going to be used quite a few times though.
Posted : 29/12/2019 6:37 pm
