Any steering rack e...
[Closed] Any steering rack experts in?
A union is leaking fluid on my Citroen C5 steering rack. It could just be an O ring, but Citroen don't list the part. Their solution is a new 800 pound rack. It would be cheaper and easier to sort the leak than replace the rack.
Where might I find a seal ?
Posted : 04/04/2013 1:08 pm
 Dino
bearing supplier / factors
p.s
Are you sure its not the pinon gear leaking & running onto unions?
Posted : 04/04/2013 1:11 pm
There is a seal at the steering pinion valve but if its leaking out of the ends of rack then it's a new rack, are you 100% it's the rack the pipes to the rack are very common for leaking.
The main rubber to metal hydro pipes.
or something else.
Second hand rack?
Posted : 04/04/2013 1:12 pm
i am in SHOCK !
i just picked up a cheap used rack off ebay for my french van.
they love to develop leaks
you looked at taking it apart ? - if its anything like mine your getting skinned knuckles or employing a small child with small hands to do it for you.
flex head ratchet spanners ARE YOUR FRIEND !
dont be tempted by the pattern racks! even if they are half the price
Posted : 04/04/2013 1:13 pm
I'm pretty certain its leaking from the rack to rack union below the pinion. I can't see any leakage from the pinion itself.
Dingbro can do a rack for around two hundred pounds. That may have to be the solution, the car doesn't owe me much.
I've got a selection of flex head ratchets.
I might just whip off the pipe and try and see why the joint is leaking first.
Posted : 04/04/2013 1:36 pm
