Any electricians he...
[Closed] Any electricians here? Room thermostat quetsion.
I want to replace my existing mechanical room thermostat with a digital 5/2 programmable room thermostat.
My current mechanical stat has three wires connected to it, live, neutral and earth. I have a combi boiler which has a 24hr timer control on it in addition to constant and off settings.
Can I just replace this mechanical stat with a digital programmable one or am I missing a Switch Live, therefore needing the services of an electricial?
Sorry for the dull question!
Posted : 24/01/2009 10:28 am
no your not missing a sw live you are missing a neutral. don't be fool by the colors of the cable you will need to run a three core and earth back to were your cable comes from. the old thermostat is a switch but the new one has a relay in it for the switch to work it gives it better control
Posted : 24/01/2009 10:39 am
Ok. Are these existing wires likely to come from my boiler or my consumer unit do you know?
Posted : 24/01/2009 10:54 am
the cable will go back to the boiler or a joint box beside the boiler
Posted : 24/01/2009 11:02 am
They would come from the boiler because that is what is switched on & off by the stat unless you have an additional controller in between (some Potterton boilers do)
Ok, I can see those wires now. This is probably a job for a spark but thanks for your help, it's good to know what's involved though.
Posted : 24/01/2009 11:21 am
you in edinburgh ?
Posted : 24/01/2009 11:25 am
nope, near leeds
Posted : 24/01/2009 11:40 am
