Android wifi hotspo...
[Closed] Android wifi hotspot app
Has anyone found a simple android app that'll toggle between normal wifi and acting as a hotspot, turning the wifi back on when you turn the hotspot off and maybe even toggling mobile data at the same time, though I understand that's tricky on Lollipop. Yes I know I can use settings shortcuts but this can't be an uncommon requirement, yet none of the widgets or apps I've found so far have ticked all the boxes.
Posted : 15/08/2015 3:08 pm
I may be missing something here, but when I turn the hotspot off on mine using the normal settings it automatically re-enables normal wifi and reconnects to my wifi hub. So the only thing you'd have to do separately is re-enable mobile data if you want to turn that off when being a hotspot. Have just tried and it took me about 5 seconds to disable hotspot, re-enable mobile data and it to reconnect to my home wifi.
4.0.4 here which is the most up to date I can get before I get round to rooting, so maybe they've "fixed" this in more recent versions.
Posted : 15/08/2015 3:16 pm
Yeah I think they have - Moto G mk1 running Lollipop and I need to switch everything separately.
Posted : 15/08/2015 3:19 pm
