Needing a new one after many many years. They are great at keeping watertight and are compact, but is anything slightly warmer? We find after a few hours they cool unless hidden in a spare jacket or hat.
Bonus if it could sit in a bottle cage.
Must be guaranteed watertight when bouncing around hills in bottom of rucksack.
My chilli mug stays hot for aaaaaaaaaages. And absolutely water tight.
https://www.amazon.co.uk/Thermos-Direct-Drink-Flask-Stainless/dp/B0148QIJWM/
Sits in my bottle cage with hot tea, on cold winter rides. I've had it over four years, & it will keep stuff warm for hours. It's not an exact fit in the bottle cage, so occasionally goes flying on rougher jumpy tracks 😉
Kind of related... pro tip (which I stole from someone else): if you cut an old sports bottle at the right point, you can make a sleeve that a Lifeventure mug fits into, which then stays put in a bottle cage. It'll also help add a bit of insulation, though I suspect most heat is lost through the lid... I know what you mean about wishing they would stay hotter just a bit longer.
I’m huge fan of Ocean Brew Flask.
I use mine every day without fail. Keeps everything super hot, proper waterproof (upside down in bag) and really robust. Ideal size as well.
Spendy but lasts well so good investment.
*edit, real life life science in action, I just took a slurp after making coffee at 9am and its almost hot enough to burn my mouth. Not quite, but almost.
Excellent. I'll try that.
I bought one of the Singletrackworld Klean Kanteen bottles and am impressed with it. Top doesn’t leak and it keeps drinks warm for hours
I have s Yeti Rambler. There’s screw or slide lids, the screw is properly sealed and keeps a drink hot for ages.
Me too its taken a beating too. Gets used daily.
+1 for Ocean Bottle Brew Flask
Properly insulated and drip proof.
Only slight niggle is for milk based drinks like Latte, it’s a bit slow to sip from.
On the plus side, you can buy spares and I think they replace for free the first time you lose or break a bit.
We have three Contigo mugs/flasks and they are excellent. Don't leak, very robust, keep contents hot.
Might work in a bottle cage too. Can't remember if I've tried that.
Yeti rambler here - not tried it in a bottle cage to be honest but it does keep tea warm all day, it’s very watertight and it’s quite nice to drink from in a way no other travel mug I’ve experienced is (the profile of the lid gives an inch of open cup at the top rather than sooking through a hole and hoping you don’t scald your mouth)
I wouldn’t be putting an expensive mug in a standard bottle cage, although I guess it depends what kind of trails you ride. I use a Stanley mug, which fits conveniently into my Fox hippack bottle holder, and is really secure there. The mug isn’t huge though,
