A UK Garmin in Cana...
[Closed] A UK Garmin in Canada
Will my UK sourced Edge 200 and/or F<span style="font-size: 0.8rem;">orerunner 610 work in Canada? </span>
Only looking to use the tracking functions
And yes, i appreciate that the G in GPS stands for Global....
Posted : 03/06/2018 10:12 pm
Yep GPS be global so it will track you, might take a while to lock on so switch it on when you get there and let it find out where it is before you ride.
Posted : 03/06/2018 10:15 pm
Marvelous, thank you.
Posted : 03/06/2018 10:16 pm
Yes, sync to Garmin Express / Connect before leaving so it has up to date GPS data. My Garmin takes less than 30 seconds to get a lock after being dragged 7000 miles.
Posted : 03/06/2018 11:36 pm
My UK Forerunner has worked fine since I got to Canada, so.... yes.
Posted : 03/06/2018 11:45 pm
My NZ based one has worked fine in the French Alps, Central Asia and ****stan.  I'm sure Canada will be no issue
Posted : 04/06/2018 12:13 am
 fifo
You might just find that there’s an option to change the projection to one that matches your bit of the globe a bit better. Given the globe isn’t actually a sphere, this might help slightly with altitude data in particular.
Posted : 04/06/2018 2:49 am
My old Harmon worked fine just had to change the grid system if you want to use the grid references for paper maps.
Posted : 04/06/2018 9:09 am
What Flaperon said.  My old Garmin didn't take long to sort itself out in all the places I go to around the world.
Elemnt Bolt is working a treat in Durban at the moment 🙂
Posted : 04/06/2018 9:48 am
 xora
It will work, mine travel all over the world with me.
Stick the free OpenStreetmap maps on it and you will even get maps working 😀
Posted : 04/06/2018 11:24 am
I use a garmin forerunner with the connect app when i go to Canada.
only issue i found, was that it didn’t recognise when i skated along a canal 😂😂😂
other than that, worked perfectly 👍
Posted : 04/06/2018 11:29 am
