A question for geom...
[Closed] A question for geometry lovers:
Triangle ABC
Angle A is 100 deg
Length AB = length AC
Length BC = 5
How long are AB/AC?
Please show all you workings.
Posted : 08/09/2014 4:06 pm
Do I win a prize?
Posted : 08/09/2014 4:08 pm
Posted : 08/09/2014 4:09 pm
Do I win a prize?
Where are your workings?
Or in this case, maybe not.
Posted : 08/09/2014 4:12 pm
Cut the triangle in half (to make two right angled triangles). It's just SOHCAHTOA then ๐Ÿ˜‰
Take a midpoint of BC, call it D.
Draw a line between A and D. We now have two right angled triangles, with an angle A/2 of 50 and a known Opposite of 2.5.
Trig tells us SIN(angle) = O / H.
So, H = O / SIN(angle)
H = 2.5 / SIN(50)
H = 3.26
I think. It's a quarter of a century since I last did that.
Posted : 08/09/2014 4:13 pm
Cougar wins!
Thank you......
Assuming he's right of course.
Posted : 08/09/2014 4:16 pm
It feels about right.
The 100' angle will give you slightly shorter sides than if it were a 90' angle. If it were 90' then you could use Pythagoras' Theorymajig.
[AB]^2 + [AC]^2 = [BC]^2
As AB and AC are the same,
[BC]^2 = 2([AB]^2)
[AB]^2 = [BC]^2 / 2
[AB] = SQRT(25/2)
(ie, square the hypotenuse, divide by two, and square root it)
Which gives us a side of 3.53 - nominally longer than the 3.26 for the 100' angle, as predicted.
Posted : 08/09/2014 4:25 pm
Yeah 3.26 is correct but there is no need to mess about with pythagoras. The internal angles are 100, 40, 40 and you know one length so it's just a matter of applying the sine rule.
Posted : 08/09/2014 4:32 pm
Is there a second prize for getting the answer first?
Posted : 08/09/2014 4:34 pm
Is there a prize for being first to provide instructions but not actually doing the workings for the lazy OP? ๐Ÿ™‚
Posted : 08/09/2014 4:35 pm
Cougar is correct.
Posted : 08/09/2014 4:42 pm
Oh, I know, I was just doing it as a half-proof to see if I was in the right ballpark. Last time I did trig was at school so I wasn't sure I'd remembered it correctly.
Posted : 08/09/2014 4:49 pm
It's got something to do with pie right? It's always about the Pie!
๐Ÿ˜‰
Posted : 08/09/2014 4:53 pm
