A cheaper 135mm wid...
[Closed] A cheaper 135mm wide rigid fork
 Olly
I've had an idea, involving making a fork into a pedestrian load lugging wheel. Got so far into proof of concept using a normal fork, and concluded It would be best with a 135mm wide fork, such as a Surly Moonlander fork.
Any suggestions as to where I can get such a thing at significantly less than rrp on a moonlander forks (150 quid ish)
any budget alternatives?
Posted : 26/07/2021 10:38 pm
 Olly
" http://www.cruisershop.eu/towar/89/150-mm-wide-rigid-fork-fatbike-fatcruiser-old-135-26-1-18-200mm-stem-ahead-black-steel-oozee.html
Found these. Could work. Don't have any of the mounts the surly fork has but could then braze on the mounts exactly where I wanted them, but that would involve getting into brazing, which will cost more than the difference.
Posted : 26/07/2021 11:12 pm
On One Fatty forks are 135 I think. They use rear disc spacing or something awkward like that.
They go for peanuts, just sold a set for a tenner.
Posted : 27/07/2021 1:12 am
https://www.carboncycles.cc/?s=0&c=105&p=1664&tb=002
Posted : 27/07/2021 1:27 am
Planet x do a steel rigid fork. A few different ones from about £80 I think.
Posted : 27/07/2021 10:50 am
