(Posting for a friend..... all replies appreciated)
I’m a first time buyer looking at a second hand Ragley hardtail on eBay, it seems to be in good condition from description and photos, seller has stated two issues, first is that the bottom bracket has been cross threaded (it’s a hope bottom bracket so bearings can supposedly be removed without removing cups), second issue is that there is a bit of play in the rear wheel. Would be great if someone could let me know what’s the worst case scenario about further cost of servicing these issues
If the BB is staying in ok then the cross threading isn't an issue, but personally I would be asking more about it, whether it had been chased, have a look at it etc.
Wheel - depends on the hub. If it's a cheap Shimano, it might be shot, might just be a case of some work and cheap parts - impossible to say.
Look at transmission wear and condition of all bearings also.
BB would put me off, there will be plenty of other bikes around without issues.
Yep definitely worth a decent discount but I wouldn't buy unless you can check it.
Much appreciated. Thanks for the advice.
