mk1 kickr doesn' appear to be an option to calibrate the turbo any more. ย restarted a couple of times, did a session where it seems it wasn't really working as I just sat in the same gear at around 250w no matter what the gradient
what' going on haven' changed any settings since last ride 3 or so weeks ago. ย any recent upgrades change stuff?
Can you calibrate within the Wahoo Apps ?
I appear to have two kickrs in devices one with FE-C in the device name different to the other. ย Which one should I use / what' the difference, sure there was only 1 when I set it up a couple of years ago....
C is the changable/Controlable one within Zwift.
yes seems I've calibrated ok in the app. ย there was an advanced calibration I was going to do but it said it would disable the strain gauges permanently. ย weird.
I've changed the devices to the one with C in. ย will have to see if tomorrow's workout is ok. ย strange how it has just suddenly changed
Do you mean the spindown? Were you doing in once you've started to ride? I couldn't figure out how to do it at first as i was trying to do it from the main menu as its pairing to the Bluetooth devices, but then realized you needed to hit settings once you're actually on your way. Menu - Pair & there should be the spindown option. probably because it should be done when the trainer has been warmed up for 10 mins.
At least that's what i think but may be talking utter bobbins
