'zocchi 55 R?
[Closed] 'zocchi 55 R?
[#3906415]
So I want a coil fork for an Alpine 160. Was keen to go back to Marzocchi now that they seem to have put their problems behind them.
Was planning on the all-singing, all-dancing 55 RC3 Ti, but it now only comes in 170mm, which blows the warranty on the bike. Not internally adjustable apparently.
What's the damping performance like on the basic 55R?
Posted : 24/04/2012 12:41 pm
performance = terrible.
weight = excessive.
stanchions = made of cheese (scratched badly after one ride).
if you don't mind the weight, just get some domains, they're ace.
Posted : 24/04/2012 12:56 pm
 hora
I know its not coil but....Why not get the 55 TST2 air from Winstanleys? I've just bought a set.
Posted : 24/04/2012 12:59 pm
They're heavy, but stiff as hell. Performance is plush.
They have been hyped but the Marzocchi range is terrible.
The only 140mm is a travel adjust, no 160s in RC3. Not internally adjustable. Shame, I was considering buying some.
http://www.ukbikestore.co.uk/product/85/y91219130g05s/marzocchi-55-micro-ti-fork-2012.html
Stevo, these suit your needs?
Posted : 24/04/2012 1:00 pm
There are several places that still have the 160mm 2011 55 RC3 Ti available.
Posted : 24/04/2012 1:01 pm
 hora
Sir Walter Really?
Would that be 1.5 steerer? 😉
Posted : 24/04/2012 1:02 pm
Tapered or unspecified (which could be anything, really..).
Posted : 24/04/2012 1:06 pm
If you break the bike swap the forks back to the original ones.
Simples.
Posted : 24/04/2012 1:10 pm
 wl
That's assuming he doesn't break his neck at the same time as the headtube.
Posted : 24/04/2012 1:14 pm
Check the axle to crown on the 170mm compared to the 160mm. I seem to recall with the 44 rc3ti the 2010 140mm was only about 5mm shorter than the 2011 150mm version. If it's such a little amount I would definitely phone orange and speak to their tech dept - they may judge that a 5mm axle to crown difference means bugger all (which would be correct!!).
 hora
Its a 160mm Alpine not a 100mm hardtail frame
Posted : 24/04/2012 1:46 pm
Really want a proper coil fork - it's going to be used day in, day out in the Alps all summer long (hopefully for more than one summer!).
Just more peace-of-mind on the reliability front than air.
Posted : 24/04/2012 2:54 pm
[url= http://www.kustombikes.co.uk/forks/fox_36_van_160_suspension_forks_2012 ]Fox 160mm vanillas???[/url]
Posted : 24/04/2012 3:02 pm
Those Micro Ti's no good then?
I thought they were supposed to be very good?
Posted : 24/04/2012 3:06 pm
wrecker - they're an air fork though. Only negative spring is coil.
Posted : 24/04/2012 3:11 pm
I run basic 55R's. Cant fault them really. Rebound damping does the job, and occasionally I squirt a bit of silicon spray on the seals to keep them nice and plush. Had them for two years now and still perform like new. prefer them over my 2006 revelations I had before
Posted : 24/04/2012 3:20 pm
 hora
In that case I don't see whats wrong with the 55R.
