zesty 2012 1 x 10 f...
[Closed] zesty 2012 1 x 10 first try alignment problems
I have decided to give 1x10 a try with a oneup 42t, ive just fitted all the kit on my 2012 zesty, sram gx 10 speed mech and shifter. I am using a standard downhill front chainring and am alarmed by how easily it seems to drop of i.e. quarter/half a turn. I am aware i need a NW chainring, but will this really cure an issue as bad as this? I am assuming there we be a constant grinding noise with this much of an anlge? Have I done somthing wrong? I can't adjust BB position as it is a press fit with no spacers. I have put the front chainring in the middle position. The chain is dropping off to the inside.
The bike frame etc have been sat around for a year as I haven't had the time to put together, and I was really looking forward to the upgrade from my old prophet. So I am a mixture of confused, worried and bloody p'd off that it seems to be buggered! I think my first step is to calm down and then any help would be greatly appreciated. Maybe my last step is a sledgehammer to bash the bottom bracket across? ๐Ÿ˜ฎ
Posted : 24/10/2015 3:34 pm
I ran 1x10 on a 2012 Zesty with no issues. Mind, it was a Shimano set up and a normal 11-36 cassette.
It was a bit before narrow wide chain rings were so cheaply available so I used a chain guide.
Posted : 24/10/2015 5:22 pm
