yt tues -single cro...
[Closed] yt tues -single crown fork
Hallo, i have a tues 2.0 2012 ltd edition. (26'' deemax wheelset)
The current fork is a 2012 888 rc3evo v2.
The fork's steerer tube should be 1.5 non-tapered.
YT told me that the 2012 frame uses a a ZS56/ZS56 headset.
1) what fork steerer tube is compatible?
2) What 2016-2017 single crown 180mm fork can i put on the bike?
Posted : 23/01/2017 1:17 pm
As it's a 1.5" steerer tube currently any of the new 180mm forks would fit but you would need to change the top part of the headset to take a normal tapered steerer.
Not many forks out there with a 1.5" steerer tube.
Posted : 23/01/2017 1:21 pm
You could pick up a secondhand Totem with a 1.5in steerer, I used to have one and it was great.
Otherwise I'd look at a Marz 66 RC3 ti and adapting the headset as stevied suggests.
Posted : 23/01/2017 1:33 pm
Is the frame adaptable to other headsets?
i see that the fox 36 float is 1.5 tapered. (moreover it is compatible with 20mm axle)
http://www.ridefox.com/2016/family.php?m=bike&family=36
what modification would i need?
Posted : 23/01/2017 1:51 pm
That for is a 1.5" taper meaning 1.5" at the bottom, smaller at the top. It's not a full 1.5" steerer.
Posted : 23/01/2017 2:00 pm
You just need a new headset cup for the top
Posted : 23/01/2017 3:24 pm
thanks guys! can you gine me an idea of a headset that will do the trick?
Also except for the fox float 36 (and discontinued totem and marz 66), what other 180mm 26'' fork is there?
Posted : 23/01/2017 5:38 pm
Are you absolutely sure the 888's had a 1.5" steerer tube? I might be wrong and it might be some wierd fork, but the 888 should be a 1.1/8. The frame will take a 1.5" if needed, but DH forks don't because it offers little benefit to dual crown forks.
Posted : 23/01/2017 5:56 pm
Not sure if you can still get a Fox Vanilla 36 in 180mm?
Posted : 23/01/2017 6:02 pm
sorry, i checked in the internet and i guess it must be 1-1/8".
-can you give me an idea of a headset that will do the trick?
-Also except for the fox float 36 (and discontinued totem and marz 66), what other 180mm 26'' fork is there?
Posted : 23/01/2017 7:04 pm
Xfusion metric is a 180mm fork with 20mm maxle.
No idea on headset sizes, that's a black art as far as I'm concerned.
Posted : 23/01/2017 7:39 pm
