YT Jeffsy Bottom Br...
[Closed] YT Jeffsy Bottom Bracket Help.....
[#9958222]
Hi everyone,
My mate has a YT Jeffsy 2016 model and needs a new press fit bottom bracket. We’ve looked at the spec and it’s a Raceface BB92 from what I can find but can’t find the size anywhere!
Any help would be hugely appreciated .
Cheers.
Posted : 25/04/2018 11:17 am
92mm GXP
Posted : 25/04/2018 12:03 pm
Thanks, are they a standard diameter and length for YT? There seems to be loads of different ones online at chain Reaction Cycles?
Posted : 25/04/2018 12:31 pm
It'll depend on the model, from memory some use a crank with a 24mm axle and some use one with a 30mm size.
Posted : 25/04/2018 2:05 pm
I went for a hope one, seems to be lasting a lot better than the raceface original.
im pretty sure they all use the Cinch 30mm axle size (mine did).
Posted : 25/04/2018 2:57 pm
Thanks everyone for your help should have him sorted out now.
Posted : 25/04/2018 3:16 pm
Not all are 30mm axle. I made that assumption, and then found out that the one on my girlfriend's is 24 (entry level Al model)
Posted : 25/04/2018 6:40 pm
The 2016 "should" have a 30mm RF Turbine crank from memory?
I installed a Hope one on my carbon Jeffsy.
Posted : 25/04/2018 6:53 pm
I've just installed the 3rd RaceFace BB92 in 1200 miles. Just dont seem to last.
If you want to replace your Jeffsy BB with the same one again here is the link (my Jeffsy is a 2016 AL One):
http://www.chainreactioncycles.com/race-face-cinch-30mm-series-bottom-bracket/rp-prod113372
Any problems fitting the Hope version? Did you need spacers? I'm looking at Hope right now....
Posted : 13/05/2018 8:49 pm
