Yeti turquoise Fox ...
[Closed] Yeti turquoise Fox Forks
[#5252223]
Just bought a yeti SB66c with and pair of Yeti turquoise Fox Forks, but the steerer is a bit on the short side, waiting to try a stem with a bit of raise,
Can the steerer tube be replaced?
Or is it a case of sell them and get another set?
Posted : 16/06/2013 7:07 pm
I think they're pretty rare, only sold as part of special editions of Yetis. Unlikely you will get similar forks I doubt? Best option is a new CSU from Mojo but fairly pricey, especially if they're Kashima.
Posted : 16/06/2013 7:18 pm
 MSP
How much rise do you want? I just stuck a hope stem in the classifieds, 70mm x 25 degrees that might be a solution to your problem.
Posted : 16/06/2013 7:29 pm
There is a set in I'd cycles in Ilkley. Looked lovely all yeti toothpaste green.
Posted : 16/06/2013 7:37 pm
Why not just buy the equivalent normal fox forks and swap the stanchions, will take 5 mins, then sell on the originals with short steerer!
Posted : 17/06/2013 8:16 am
riser bars?
Posted : 17/06/2013 8:26 am
Try a renthal duo stem low stack height and a slight rise
Posted : 17/06/2013 8:35 am
You can't buy the steerer on its own, but I think you can get the crown/steerer/upper leg assembly. Get in touch with Mojo.
Posted : 17/06/2013 8:50 am
Or you could take the cheap option and use on of [url= http://www.ukbikestore.co.uk/product/41/2929612101/bbb---extender-steerer-extender-286-254mm.html ]these[/url].
I've got one on a pair of Bombers and it works great.
Posted : 17/06/2013 9:00 am
getting a new crown resprayed the right colour should be possible.
but then you coudl but a complete new fork and get it sprayed the right colour too, I guess.
Posted : 17/06/2013 9:02 am
If you find you need to replace the forks entirely, you can replace standard Fox decals with [url= http://www.slikgraphics.com/collections/fork-decals-fox/products/fox-yeti-edition-decal-kit ]these ones[/url] which are a turquoise treat.
Posted : 17/06/2013 9:10 am
Thanks for all the help.
Going to try a renthal stem and see how I get on. If not may end up selling and just get a standard colour (black or White).
Posted : 17/06/2013 6:27 pm
