I'm having issues with working out what I actually need so I'm hoping some knowledgeable person on here can help!
I've got a 2016 sb6c. The owner manual says it's fox parts 214-09-035 and 214-09-006 but that seems to be the complete assembly whereas I only want the bushings.
The tf tuned site has me totally baffled as to what I need to buy! Anyone care to help a confused biker?
Phone tftuned tomorrow, it is the easiest way.
You can buy our BETD Strong Bushes for your Fox shock and all you need to order is one 22.0 x M8 and one 45.0 x M8 both for Fox fitting (12.7) Then you can just replace the hula hoop when it's worn and with the shaft being stainless it will last a lot longer than the Fox ones
Another vote for tftuned. Stock Fox bushings are made from a combination of blu-tak and window putty and don't last very long. Rather than replace like for like, swap for the heavy-duty tftuned bushings and buy a spare bag of the press-in part, which is the only bit that will rare. Cheap as chips and quick and easy to swap when it wears.
Burgtec Ti for a bit of hidden bling - only you'll know how much you spent ;o)
