XTR Shadow rear der...
[Closed] XTR Shadow rear derailleur cage spring failure
[#1589076]
Just at the end of a ride yesturday I noticed the chain had become very loose it seems like the return spring for the jockey wheel cage is not working and holding tension on the chain had a quick look and it appears that the spring is very rusty anybody had a similar problem or do you know if you can buy it as a spare part.
Posted : 09/05/2010 11:08 am
 br
oil it?
Posted : 09/05/2010 11:31 am
Tried that had another look seems to be a lot of side to side play possibly the spring cage bolt bent ?
Posted : 09/05/2010 1:14 pm
