I quite possibly could be being an idiot but put a Rad cage on my XTR mech and now it's fouling on the 42 T rad ring.
Have i done something very stupid or missing something obvious?
I've messed with the B screw but can't get the clearance. Chain too short?
[url= https://preview.ibb.co/gSSCnF/IMG_0547.jp g" target="_blank">https://preview.ibb.co/gSSCnF/IMG_0547.jp g"/> [/img][/url]
[url= https://preview.ibb.co/b0HZ1a/IMG_0548.jp g" target="_blank">https://preview.ibb.co/b0HZ1a/IMG_0548.jp g"/> [/img][/url]
[url= https://preview.ibb.co/iQVXnF/IMG_0549.jp g" target="_blank">https://preview.ibb.co/iQVXnF/IMG_0549.jp g"/> [/img][/url]
Any help is appreciated.
Thanks
Chris
It's a pain but thread the b screw in from the 'wrong' side to get more clearance.
I thought the Rad cage removed the need for very high b tension. Mine certainly works with hardly any, but its a 40t. Worth playing with though. Maybe you need a goat link
Thanks guys. Maybe I'm confused but I thought that screwing the b screw in meant great distance between the big ring and the top jockey? This is the mech arm fouling.
Thanks
Just a thought. Can you slacken the bolt into the dropout and rotate the hanger so the mech sits a little lower? That might give a little more clearance
It does look like the mech is angled up a bit, or maybe it's just the angle of the photo. I didn't need to touch the b screw when I fitted a rad cage.
Will check tomorrow morning but I suspect I might have ballsed something obvious up when replacing my mech!
Thanks all
Without my bike here in front of me I can't be sure but it looks like you've not installed the upper derailleur properly. I did the same thing initially on mine when changing to 1 x 11, it's a simple fix.
Something doesn't look right I agree. Will check and report back!
I be just woken up after being on call out last night so I'm not firing on all cylinders, but at first glance, it does look like the B-knuckle is at the wrong angle.
Looking at the top pic, there is daylight under the anti rotation tab which is actually supposed to sit behind the tang on the drop out. I think you've let the mount rotate as you've tightened the mech bolt.
Just in case anyone was interested the mech hanger was very slightly bent and also I needed a couple of extra links (although that didn't cause the fouling).
Happy days and more range than....something with lots of range. 😳
It's my how big it is, but what you do with it!
Something inside me is making me feel sorry for the derailleur in the bottom picture.
