xtr pistons too far...
[Closed] xtr pistons too far retracted - help...
[#4713737]
I was in the process of sticking some new pads in my 980 brakes, and I think I've pushed the pistons back too far.
When the lever is relaxed they sit flush with the caliper body, and when the lever is pulled they protrude by just a couple of mm.
In this situation the brakes work but only right at the very end of the lever stroke.... 🙁
How can I get the 'self adjustment' to work so the pistons don't fully retract back into the caliper when I release the lever?
(Brakes were in air free condition before the pad change & bleeding since has not shown any bubbles)
Posted : 04/01/2013 7:24 pm
I'm sure if you just continue to pump the brakes they'll re adjust up..you can't put the piston back to far
Posted : 04/01/2013 8:00 pm
