XTR CHAINSET FITTIN...
[Closed] XTR CHAINSET FITTING
Do I need the TL-FC35 Tool for fitting a M970 XTR chainset? Or is this tool simply for the removal?
Posted : 09/06/2011 11:01 am
No - just removal if you use say fine nose pliers to put the last nylon thread protector ring (crank cap) in at the end.
I wrote this article if its any use?
http://www.cyclistno1.co.uk/features/maintenance/servicing-xtr-cranks.htm
Posted : 09/06/2011 11:04 am
Very good article, thanks for that. Glad I don't need that TL-FC35 it's so expensive!
Posted : 09/06/2011 11:26 am
I got mine 2nd hand from STW classfieds - BTW you get the tool with teh full retail XTR crankset but not with an OEM set as I found out 😉
Posted : 09/06/2011 11:31 am
I managed to get my XTR 970 chainset for under £100 on ebay with bottom bracket and it was boxed! Now that's a bargain. Only had to buy a TL-FC32 for £12 to fit the bottom bracket.
Posted : 09/06/2011 11:34 am
I'd look at getting that tool sooner rather than later - when you do need to remove the chainset you'll find everywhere is out of stock...
Posted : 09/06/2011 11:40 am
Cheapest I could see for that tool was £29.99, anyone seen it cheaper?
Posted : 09/06/2011 11:42 am
 rob2
I've got one if you want to borrow it (reading oxfrod area)
Posted : 09/06/2011 11:47 am
£24 from winstanleys but I would suggest putting up a wanted in STW or go to ebay 🙂
Edit: as above if you are near Exeter I have one you can borrow if you ever need it 🙂
Posted : 09/06/2011 11:49 am
starbike.com have them in stock for 22euros - not sure what they charge for postage, though.
anyone around derby with one?
Posted : 19/08/2011 8:32 pm
