I have a 2*10 XT setup, thinking about going 1*11 xtr. If I miss the extra top end am I right In thinking I can bolt up an extra ring on the xtr spider and use the existing front xt shifter and deralliour?
Posted : 14/06/2018 10:21 pm
You may get away with the medium cage on a hardtail, but essentially, yes.
Posted : 15/06/2018 8:11 am
Chainline may be out, which can cause some issues with pie plate cassettes.
Posted : 15/06/2018 8:14 am
Replacing the single ring with a pair of double rings will correct the chainline. They use the same crank. You’ll need the double ring caps for the spider though.
Posted : 15/06/2018 8:34 am
Ah, ok. I can vaguely recall that on 10 speed cranks the chainline was adjusted between 3x ad 2x. So if you wanted 1x, a 3x was the best place to start. Obviously different on the current generation.
Posted : 15/06/2018 8:39 am
