XT shifter to Hope ...
[Closed] XT shifter to Hope Tech 3 lever - I Spec B
[#11902874]
Hi
I'm trying to fit an I Spec B Deore XT shifter to a Hope Tech 3 lever and tearing what remains of my hair out.
I don't have a 16mm M5 bolt yet as I thought the bolt that came with the shifter would be enough. It's too short. I do have the M5 nut which I thought I needed but for the life of me I can't see where it should go. From what I can tell the bolt is the only connector needed?
Help? And thanks, Gerry
Posted : 28/05/2021 7:47 pm
https://flic.kr/p/2m26qdr
https://flic.kr/p/2m2fwVj
https://flic.kr/p/2m2dXPW
First attempt at pics - hopefully worked!
Posted : 28/05/2021 7:50 pm
 nbt
The square bolt goes in the space on the inside of the handle
Posted : 28/05/2021 9:26 pm
Not sure where you mean to be honest
Posted : 28/05/2021 10:07 pm
 momo
I don’t think you need the square nut, later levers appear to be threaded and not require it.
Posted : 28/05/2021 10:08 pm
That was my thinking Momo. The lever is threaded. I think I just need a 16mm M5 bolt.
Posted : 28/05/2021 10:12 pm
 poah
Posted : 30/05/2021 11:11 am
The whole problem is where that square nut should go. There isn't a recess for it on my shifter or lever. I have an I spec B shifter and a Tech 3 lever. Either I'm missing something (which is far from impossible!) or that diagram is wrong or out of date. If anyone has a a pic of the square nut in situ on a Tech 3 lever I'd be delighted to see it!
Posted : 30/05/2021 12:32 pm
The newer tech 3s don't use the nut. That's used on the earlier version tech 3s with the holes rather than dimples on the lever blade.
Bolt only. From memory I think a disc bolt does the job
Posted : 30/05/2021 4:16 pm
Excellent cheers for that sharpy. I have a few M5 x 16mm on order and i think one of them will be perfect.
Posted : 30/05/2021 7:27 pm
 nbt
This is mine (well, Mrs NBT's)
[url= https://i.postimg.cc/7ZJc96xN/DSC-0173.jp g" target="_blank">https://i.postimg.cc/7ZJc96xN/DSC-0173.jp g"/> [/img][/url]
[url= https://i.postimg.cc/sDNq5SRX/DSC-0174.jp g" target="_blank">https://i.postimg.cc/sDNq5SRX/DSC-0174.jp g"/> [/img][/url]
Yes I've used a six sided nut as my lbs didn't have the correct one in stock and hope are quoting several weeks lead time
Posted : 30/05/2021 9:49 pm
Thanks for taking the time to do that for me nbt. Much appreciated. Mine doesn't have the recess your six sided nut is sitting in.
Posted : 31/05/2021 8:40 am
Someone else posted about this last week, zooming in on the second photo shows the new version is threaded so it just needs an M5 bolt as already mentioned, surprised you don't have one knocking about, I've got loads but you could have just used one of your disc rotor bolts to avoid delaying your build.
Posted : 31/05/2021 9:15 am
