XT M8100 crank repl...
XT M8100 crank replacement options
I keep smacking my XT cranks on roots and rocks, so am considering going to 165mm, are there any potions other than Shimano?
Hope and E13 only appears to be available in 30mm spindles.
Posted : 05/07/2024 9:30 pm
Dmr axe would be my choice. Look lovely, super strength, just seem to work. I'm eyeing up the silver which look amazing
Posted : 05/07/2024 9:47 pm
Ah, dmr are 30mm as well
Sorry
kelvin and kelvin reacted
DMR Axe also need a special BB.
Posted : 05/07/2024 9:49 pm
In the realm of light/cheap/tough, imo it's hard to beat whichever Shimano fit your budget tbh.
The Hope 30mm BBs are pretty good, so I wouldn't let that standard put you off.
Cracks do nothing for me so I'd find it hard to look elsewhere, especially when I hear the horror stories of RF carbon failures and Hope fiddlyness. I had some E13 one which were a total PITA, but, E13, so that was predictable.ย  Plus, coloured cranks are gopping..
Posted : 05/07/2024 9:52 pm
RF turbines. Yes 30mm but what's the problem there?
Posted : 05/07/2024 10:59 pm
RF Aeffect or Aeffect SL are sensible money, 24mm axle and let you use their tough as old boots steel chainrings. Come in 165 as well.
Posted : 06/07/2024 8:53 am
StuF and StuF reacted
If you are happy to stick with Shimano then I have some new XTR 165mm that I bought after a PSA on here. You can have them for what I paid.
Posted : 06/07/2024 9:23 am
What't the problem with Shimano? ย Are you actually bending or breaking them? they're lighter, stronger and cheaper than almost anything else and they have the best/easiest/most reliable axle/crank interface IME. I've had various Hope, RF, SRAM, Middleburn over the years but other that looking different all were worse than Shimano in various ways.
Personally wouldn't even bother with XT. ย The SLX looks better, wears in better, and has the same construction and weight (IIRC the weight difference to XT comes from the XT composite chainring) and is cheaper.
Posted : 06/07/2024 10:44 am
bikesandboots, sillyoldman, kelvin and 3 people reacted
@thered ive sent you a PM
Posted : 06/07/2024 10:54 am
It does seem to appear that other than a few cheap GPX or the entry level RaceFace, everything is now 30mm or dub. Nothing wrong with good BSA30 bottom brackets like the Hope and nothing wrong with Shimano cranks.
I am about to move a set of RaceFace Turbine from a boost mountain bike to a gravel bike. That's only possible because the chainline is in the chainring, not the cranks. You can't do the same with Shimano.
Posted : 06/07/2024 11:05 am
b33k34 and b33k34 reacted
@onzadog you can also play with the axle length. You may find a Easton cinch axle gives a better chain line or the slightly shorter RF axle from before boost. There is a massive tech doc on the RF site that gives the measurements for the different combinations.
If your turbine's are boost era they should have a a rf136 axle. For your gravel usage a rf134 or the 128 (iirc) from the road sets would be better.
Posted : 06/07/2024 12:18 pm
@onzadog ย hmm. ย You *can* fiddle with chain lines on Shimano bit it was never elegant.ย
Posted : 06/07/2024 3:45 pm
@nixie they are 134. I boosted them via the chainring as they are from 2016.
Posted : 06/07/2024 4:36 pm
nixie and nixie reacted
@thegeneralist what model of xtr?
https://flic.kr/p/2q2JS3k
Posted : 07/07/2024 3:03 pm
@ beargrease
I appear to have reached my limit of PMs.
Can you me your phone number and I'll phone you
Posted : 07/07/2024 3:12 pm
Ooooh the shiny black one ๐Ÿ™‚
was really meaning like 9100, ย 9130 etc. Should be written on the end of the drive side (left crank will just say 9100 I think).
Posted : 07/07/2024 7:27 pm
@thered 165 XTs on my proper bike if you want a spin. I put 30t chainring on as it does make a difference in power/ torque whatever over 175.
Posted : 07/07/2024 11:13 pm
SLX come in 165 and I believe the crank arms may be slightly lighter than XT.
I can vouch for them being durable and reliable.
Slight lack of third-party options for Shimano DM rings, but I'm happy to suffer than for the "it just works" design.
Posted : 08/07/2024 10:53 am
The Shimano rings are way more durable than aftermarket options anyway.
Posted : 08/07/2024 10:57 am
Correct me if I'm wrong, but I don't believe they make a 28t ring?
Posted : 08/07/2024 11:06 am
XT comes in 28T
Part no SMCRM85Z8
Posted : 08/07/2024 11:13 am
chakaping and chakaping reacted
Nice one matey, I'll keep an eye out for discounts and give it a try next time.
Posted : 08/07/2024 11:24 am
@thegeneralist msg sent
Posted : 08/07/2024 11:25 am
The ones pictured above are FC-M9120.
U02sgb
Posted : 08/07/2024 12:47 pm
