XT M8000 shifter wi...
[Closed] XT M8000 shifter with SRAM cassette/mech
[#7439802]
Does this work?
I've had a search but can't find a definitive answer.
So if I replace my SRAM 11 speed shifter for a Shamano XT 11 speed shifter will it work correctly without any major hassle.
Also is there a cheaper option to the SRAM XG-1180 cassette (I'm new to SRAM stuff!)
Posted : 06/11/2015 6:44 pm
No, the Shimano shifter will not work with a SRAM mech, use a SRAM GX one.
For the cassette you can look at XG-1175/1150.
Posted : 06/11/2015 6:52 pm
Does the Sram 11-spd stuff work with a shimano 11-spd cassette?
Posted : 06/11/2015 7:00 pm
DickBarton - Member
Yep
Posted : 06/11/2015 7:20 pm
Sweet...saves a small fortune when mine wears out!
Posted : 06/11/2015 7:48 pm
DickBarton - Member
Depends - you'll need a different freehub for a Shimano cassette - might not save much if you need to buy that too
Posted : 06/11/2015 7:52 pm
I'd stick with the GX 1150 cassette - lighter, tougher (I believe based on experience so far), no cassette bite, and most importantly that extra nearly 10% range, and coming in as low as £76 and dropping its not really much more than XT11 anymore.
Posted : 06/11/2015 10:52 pm
So the make of shifter must match the make of rear mech, cassette make doesn't matter.Correct?
Posted : 06/11/2015 11:07 pm
Maybe. I had to replace a guys XTR shifter a few weeks back with a GX after he bust it seeding at a race, it worked pretty well. Possibly better than the original. The manufacturers claim incompatibility but I am not convinced its not all interchangeable. Need more testing!
Posted : 06/11/2015 11:13 pm
Hmmm, the Sram cassette prices are dropping? I'm nearly £200 for mine (something I'm really regretting not checking when I bought the bike!)...so if the GX can be had for much much less then that might also work.
Posted : 06/11/2015 11:16 pm
Yeah - lots of different levels same principles:
1150 (GX) - All steel (Which is good for wear), all pinned. Currently <£80 390g
1175 (GX)- 10 steel, 1 alu cog, all pinned. 325g OE only
1180 (x1) - 10 steel 1 alu cog, 8 pinned, 3 billet 315g
1195 (x01) - 10 steel 1 alu cog, all billet bar the alu 270g
1199 (xx1) - 10 steel 1 alu cog, all billet bar the alu 265g
So in summary all but the cheapest is lighter than XTR, with a bigger range. The 1150 is still lighter than XT and as prices come down its way more viable to run SRAM 11spd now... if thats what you want to do.
Posted : 06/11/2015 11:35 pm
In my experience there is no compatibility issues with running a combination of SRAM and Shimano (11 speed only). I currently have x0 11 spd gripshift with m9000 cassette and a xtr mech, it work brilliantly and although I don't have the range I wanted closer ratios and a shimano free hub body. I also have friends who run the shimano shifters with the a SRAM cassette - this also works a treat.
Posted : 06/11/2015 11:54 pm
With a Shimano rear mech or SRAM?
Posted : 07/11/2015 11:27 am
