XT M775 levers with...
[Closed] XT M775 levers with XT M765 brake calipers?
[#4261970]
I've currently got XT M765 calipers with the dual control levers.
I've seen a set of the XT M775 servowave levers cheap online and given that I might move the bike to singlespeed i'll be need new levers anyway.
Are they compatible? Will my existing hose/fittings screw directly into the new servowave levers so will just need to give them a bleed?
Cheers!
Posted : 15/08/2012 2:14 pm
Yes, they'll work fine.
And yes, pretty sure you'll be able to swap the hoses over without new fittings, although it's probably worth getting new olives in just case they leak a bit. Will need to bleed to get fluid in the new reservoirs.
Posted : 15/08/2012 2:25 pm
Ideal, thanks for that.
Just picked up a new set for £50 inc delivery including all the bits and bobs, cables, oil, olives etc from cycle surgery.
Not bad!
Posted : 15/08/2012 3:12 pm
Don't rely on us for the right answer....ring or email Madison
Posted : 15/08/2012 3:24 pm
DezB is correct.
Mark @ Madison
Posted : 15/08/2012 3:26 pm
Parp to billyboy.
I only answer if I have experience 😉
Posted : 15/08/2012 3:30 pm
