I'm referring to the two machine screws labelled "1" here that hold the lid on:
When I first bled the brakes they started leaking from the lever lids because I failed to do the bolts up hard enough. I've since had them bled at two different shops and had the same problem after a while. The bolts have cross-head screwdriver caps - does anyone know what size the threads are so I can source some hex-head replacements?
Ta, Simon
M3X8
Madison do a kit with the topcap
but if you took them to the local hardware shop sure theyd find a suitable replacement
Nice one ir_bandito. Should be same as Hope, then 🙂
Yep, my spare Hope ones fitted which have a nice T10 cap. Only time will tell if that's cured the leaking...
