I currently have a triple 9 speed chainset fitted to my bike.XT M770
I was considering changing to a 20 speed set up and was just wondering if i could get away with fitting 10 speed rings to a 9 speed chainset?
there is a m770 10 speed chainset that looks the same as mine which is what has got me thinking.
cheers
Steve
Don't see why not iirc the m770 was the 9spd and they changed it to m771 for 10spd but it kept the same chain line so likely just a rebadging on old stock etc.
Steve - yes no problem with doing that m770 9 & 10 speed cranks are exactly the same, just marked as m770 - 10 by the pedal thread I think.
RDL-82 - m771 refers to the 9 speed 48,36,26t variant which is different & you cannot fit the m770 composite middle ring onto them
The difference between the 9sp and 10sp triple chainsets is that the rings are marginally closer together on the 10sp.
Not sure what you're proposing to do with a 9sp chainset though? Shimano and SRAM both only made dedicated 2x10 chainsets for MTB AFAIK.
I was thinking of buying some 10 speed front rings and a bash guard as a start to going 2x10. Was wondering if 10 speed rings will fit onto my 9 speed chainset or perhaps I could get away with using 9 speed chainrings with a 10 speed chain and cassette?
My bad. I've definitely seen 771's referred to as 10spd though but most shops seem to struggle to get the facts right half the time!
