always had shimano hollowtec so not too sure on the sram x9, is it just the 8mm centre bolt on the non drive side or has the 16mm bolt got to be removed first
Posted : 13/02/2012 9:54 pm
Just the 8mm, it'll press against the bigger one and self extract.
Posted : 13/02/2012 11:22 pm
Thanks for That, I take it the 16mm acts like a lock nut?
Posted : 14/02/2012 9:10 am
Yes
Posted : 14/02/2012 9:38 am
Diolch yn fawr
Posted : 14/02/2012 11:10 am
Dydw i ddim yn siarad cymraeg.
Posted : 14/02/2012 11:33 pm
Qui, un per
Posted : 18/02/2012 3:48 pm
Done bit of digging, 16mm is a cap holding the 8mm crank bolt captive, when you undo 8 mm it pushes against 16mm cap to remove crank arm. Only need to touch 16mm cap if it comes loose after crank removal.
Posted : 18/02/2012 3:55 pm
