32 upfront and something like 11-32 out back.
I assume that the dérailleur will need to take up 31 teeth. According to SRAM - shortcage capacity is 30T so ..... in theory I might not be able to use my 32 sprocket out back but will I have any other problems with this config?
running a SRAM x.0 short with a 32 front 11-32 rear.
the SRAM max is really for a tripple ring. it also depends on chain growth of the bike.
Maths isn't your strong point is it!
32 - 11 = 21
NOT 31... 😉
Short cage X7 is ideal for use on a single ring setup like the one you want to run. It's kinda what they were designed for.
true....... 🙂
Thanks very much.
Run my lads 1x9 with SRAM XO short cage on 32 chain ring and 11-34 rear cassette. Short cage has easily enough capacity for a 1x configuration.
