What 3M stuff did you go for? I'm waiting for some 'backer rods' to arrive and I've read about 3M ' tanelised strapping tape ' (its blue) being pretty much the same stuff as Stans tubeless tape but available in 45mm widths. Can't seem to find it anywhere in the U.K. though.
ordered 4 of them V rubber tyres !
thanks, hadn't seen them
Four Vee8s? 😯
I appreciate the price of ~£12 each is nice for fat tyres, but they aren't that light and they apparently self steer unless you inflate them to ~30+ PSI (which is fine for tarmac commuting like I do, albeit much more rolling resistance than JJs, but not so good off-road when low pressure is fatbikes' big advantage).
http://www.bicyclerollingresistance.com/fat-bike-reviews/veerubber-vee-8-2016
Inflating them up to 50 PSI sounds insane, it's hard enough work pumping JJs to ~30! 😆
But I guess they could be useful sacrificial lambs and they will strengthen your legs a bit more. 😉
Look at this on eBay http://www.ebay.co.uk/itm/131428818378
Slimjim - ordered this in red as the rim strip. I'll then be going with gorilla tape and backer rods.
Although my mate managed with just gorilla tape on the standard Dune rims with Floaters using the airline at the tyre place next to his shop.
yeah 4
2 for my mate, and I've got 3 fat bikes !
i'll use them in summer, and you haven't had self steer, till you have ridden endo's !!!!
My 4.8 Surly Lou has arrived, hope it fits, its massive.
Just need to find a front tyre now
Sur(e)ly the Bud? Thought they were meant to work together.
Should fit, the Bud does and I think Lou is slightly smaller on the knobs.
It's actually pretty cool IMO, the Surly carcass is pretty stretchy so as you inflate the tyre it grows much more than most- so with my Bud in the rear of the Dune, it was fine for riding and had clearance to spare, but when I pumped it up higher (20psi I think) to bead it up, it grew so much that it jammed in the frame.
Would love a Bud but cant find a 4.8. Managed via MTBR to find a US shop having a sale but delivery worked
out at $183!! Emailed them Sunday and still haven't had a reply
I'll give it a couple more weeks but i'm thinking 4.8 FBF
NW - what's the best all round F&R combo you've hit upon so far?
I'm waiting for all my tubeless gubbins to arrive and am thinking of prepping the bike for winder (snow!!) and the muddy trails that will soon be overdue - so want to try going wider up front, - and possibly out back - but don't want to be getting jammed up. Would like to keep the weight down if poss too
TBH mate it's too subjective, and I've just not used enough tyres to really say... But I like the Minions, they're great trailbike tyres. The FBR could be grippier but it's still good. I used an FBF/JJ4.8 all summer and now on FBF/FBR.
I think I've posted this elsewhere in the thread but, the Buds were actually grippier than the Minions. But I didn't like the feel. Minions have less grip- or more exactly, the carcass rebounds faster so they don't glom onto the ground as nicely- but a much livelier ride and a lot more feedback- Bud grips harder but is hard to trust because I just didn't really know what it was doing, when it was going to grip or slide... I'd rather have the consistency and transparency.
^ Sounds like FBF up front then!
Oh, FBF is also a wee bit smaller
Than a Lou mate?
Aye. It's like 4.5 or something, bit cheeky
Mmmmm, not much alternative though
Lou on the front, FBR on the rear...
How does the FBR measure up? If coming in around 4.5 I guess it's a good fit on the Dune?
Much the same. So yeah, nice fit in the dune, bit more clearance. I can do some pics if you like, that's what's in it now.
(The Bud was fairly tight in the back but because it didn't really scoop up mud, it worked fine)
Heads up guys!
Westbrook cycles have Buds at a brilliant price, i've just ordered one.
Believe there is only 1 or 2 left!
Anyone got recommendations for snow tyres? Currently have Husker Dus.
Like the look of the Flow & Dunder beists but at £140 each 😯 they might be a little too expensive for limited use. The other option might be Maxxis Mammoths.
That is a good price. Although im leaning towards FBF/FBR based on feedback on this thread..
Anyone know which compound FBF/R is best for running tubeless? (lighter weight is what im looking for)
Also, NW, did you run 4.8's on the standard Dune rims before you switched? How did they fair?
They were spot on tbh, they're 80mm rims so they're fine with wide tyres. Heavy but decent (it's been mentioned a few times in the thread but the Dune rims are the same as the On One Emmenthal wheelset and seem to be the same basic estrusion as the Halo Tundra, just with different cutouts)
What was the amazing Bud price at Westbrook? Lower than 75 squids I saw earlier, I hope! 😆
I got one
I got one
I got one
I got one
I got one
Dunno Wtf is going on there, i had a long post with pictures and it will only show part of the first line
[URL= http://i73.photobucket.com/albums/i220/HolysToy/Mobile%20Uploads/IMG_4132_zps5cxkl4qz.jp g" target="_blank">
http://i73.photobucket.com/albums/i220/HolysToy/Mobile%20Uploads/IMG_4132_zps5cxkl4qz.jp g"/> [/IMG][/URL]
Clearance with Lou
Lou next to original
[URL= http://i73.photobucket.com/albums/i220/HolysToy/Mobile%20Uploads/IMG_4129_zpsvoqvca5x.jp g" target="_blank">
http://i73.photobucket.com/albums/i220/HolysToy/Mobile%20Uploads/IMG_4129_zpsvoqvca5x.jp g"/> [/IMG][/URL]
Slight catch on cover plug, plug removed
[URL= http://i73.photobucket.com/albums/i220/HolysToy/Mobile%20Uploads/IMG_4130_zpspye4ivzl.jp g" target="_blank">
http://i73.photobucket.com/albums/i220/HolysToy/Mobile%20Uploads/IMG_4130_zpspye4ivzl.jp g"/> [/IMG][/URL]
Pretty sure NW had this?
Nice pics. Yeah NW had same issue. When I first saw that bridge bolt I figured the same would happen.
In any snow and ice that's just going to jam up.
I hate to say this but it depends on the snow 🙂whitestone - Member
I'm pretty happy with Nates but a knobbly tyre isn't always best as you'll get additional rolling resistance cutting through a crust rather than rolling over the top of it. Have a look at an Endomondo to see what an alternative snow-specific tread pattern could be.
Luckily don't get much snow in the south..
Anyone changed the bearings in the front hub?
Can't see how to get the end caps off?
From memory you should be able to see the join, you need to get a thin screwdriver or similar in there and lever them apart working around the circumference
Holyzeus - Cheers, that's cracked it
Double post
What pressure's that at? That's way less clearance than I had with the Bud but they're growthy tyres so at higher pressures it jammed solid, at riding pressures it was fine.
What tyres for snow? Depends on conditions - I had Dillinger 5s at this year's Rovaniemi 150 and still ended up walking for nearly 100km as it was knee-deep in places 8O. Just got a Snowshoe 2XL (biggest tyre currently available) to play with to check clearances - plan will be to run them with 100mm for maximum float and grip. If riding groomed trails in sub-zero conditions, most tyres work OK
Thats at 9psi NW
So how much were those Buds selling for a few days back?
Have those Vee8s turned up and if so, how do they ride at 30+ PSI?
Nobody, £74.99. Free postage, ordered Friday and being delivered Monday
Thanks Holyzeus, call me Scottish, but hell will freeze over before I agree to spend £75 on a single tyre (not that I'm convinced a Bud would fit my Wazoo with either the default fork or the Fatty Carbon one). My pair of JJs cost £5 more than that in the Easter Ebay 20% promo.
