Works components he...
[Closed] Works components headset question
Hi, asking on here as I’ve not yet had a reply direct.
Are their headsets cross-compatible? They make both cups I need, just not in a single headset package.
If I was to buy 2 headsets with 1.5 deg offset, one containing the zs49 upper and one containing the zs56 lower, would this work?
Cheers folks
Posted : 09/08/2020 7:56 am
Probably, more or less but it won't be perfect. Could it be that 1degree is the most you can get with that combo?
Posted : 09/08/2020 8:41 am
Ah I didn’t think of that! They don’t list that top/bottom combo in any angle though so I’m not sure if it’s just an unusual headset
Posted : 09/08/2020 9:35 am
I suspect it won't work, otherwise they'd be offering that combination already.
Probably worth emailing them to confirm.
Posted : 09/08/2020 11:29 am
https://www.workscomponents.co.uk/10-degree-zs49-zs56-angle-headset--to-suit-tapered-steerer-tube-1939-p.asp
This type?
As above I imagine the issue here is there just isn't room to tilt the steerer tube that far in your headset
Posted : 09/08/2020 2:01 pm
All the facepalm emojis!
Cheers dude, completely missed that
Posted : 10/08/2020 10:33 am
