I just received a 38t 104bcd round narrow wide chainring from Works Components....
The teeth don't seem to be narrow wide though.... They are what seem to be wide wide, alternating sides..... Is this correct? The chain won't sit properly in the gullets....
Bit of a ball###e as I need it for this weekend.
Any advice would be muchely appreciated.
The chain won’t sit properly
Sounds like it's not going to work, whatever is wrong with it. You have time to order a replacement Shirley?
pic?
Sounds like a machining error!
Yep, just got a reply from WC .... A machining error that shouldn't have made it into the stock.
Not easy to get hold of quickly out here in Croatia, especially not 38t....
Maybe you got a Praxis Wave Tech ring by mistake :)).
Just to follow this up..... Had swift replies from Rick at Works, friendly and professional.... All sorted.
Excellent service, well recommended.
