Wood burners with c...
[Closed] Wood burners with coal
 Gunz
[#961634]
Just read the last thread about coal fires and wondered if going the other way and using coal in my woodburner would present any problems.
Thanks in advance.
Posted : 18/10/2009 4:24 pm
 DWH
Depends...
Coal burns hotter than wood so you might burn out the grate (if there is one) quicker (sometimes a [b]lot[/b] quicker) than you would if you stuck to wood.
We've got three (relatively) cheap wood burners from Machinemart installed in various parts of the house and I regularly burn coal as well as wood on all of them. If you keep a reasonably thick layer of ash/slag between the coal and the iron body you'll probably avoid burning a hole through the bottom [i]too[/i] quickly.
Generally the more sophisticated (i.e. expensive) the wood burner is, the less tolerant of coal it will be.
At the end of the day it's just fire in a box isn't it?
Posted : 18/10/2009 5:36 pm
