I think the Wolf Tooth Camo interchangeable chainring system is great and I’ve been using it regularly to swap between a 34t and a 28t on my mtb with minimal faff. I like the Camo system as there are no hidden bolts and it takes less than a minute to pop the bolts out and change the chainring without needing to take cranks off.
I was hoping to use the same system on my gravel bike to swap between a 34t and 42t but notice the maximum chainring size that Wolf Tooth do is a 38t.
Does anyone know of a similar system that caters for a bigger 42t chainring?
I occasionally drop to the smaller chainrings for bikepacking duties and have a 1x setup.
https://www.wolftoothcomponents.com/collections/camo
Not being facetious, but isn’t that just ‘not spiderless cranks’? 110bcd, with either 5 bolt on sram or 4 on current shimano, should give you tonnes of options.
Gravel bike is currently SRAM GXP.
I guess I could swap the entire crank set over to something else. Haven’t really considered that as I assumed it’d probably be more expensive but maybe not.
Basically I need a spider / crankset that can take both a 34T and a 42T without a hidden bolt. I think 🤔
Oneup do a similar quick change system. No idea on max size though.
