Wobble in new bike ...
[Closed] Wobble in new bike tyres
My new Maxxis minion tyres arrived in the post today.
They were obviously folded.
After fitting them there was a fairly significant wobble as the wheel spun.
I played around with them a bit, deflating and inflating them but there is still a wobble, albeit slight now.
I also bought new inners but this made no difference.
Is this a common problem.
Will the tyres 'straighten out' after a bit of use?
Thanks
Posted : 26/09/2018 8:41 pm
i think it's more likely the wheel needs a true.
Posted : 26/09/2018 8:55 pm
Should have said, the wheels seem spot on.
Posted : 26/09/2018 9:08 pm
Common no; but it does happen with Maxxis. Send them back you'll get new ones if the wobble is worth replacing . It won't really come out.
Posted : 26/09/2018 9:09 pm
Had an Onza Ibex dual ply and Bontrager SE4, both new, both distorted on straight wheels with a uniform bead line.
They were also on sale!
Posted : 26/09/2018 9:31 pm
 tdog
I just had a new set of Maxxis Forekasters fitted tubeless on a new set of wheels and front seems fine although rear is a slight wobble & seems to be deflating over time at rear.
Any ideas as to what’s going on as will check before riding when bike at time is built up.
Posted : 26/09/2018 9:33 pm
 PJay
Are they definitely fully seated all the way around?
Posted : 27/09/2018 7:32 am
 Bez
IME this is normal with tyres that have been folded. If it bothers you, inflate them to a high pressure and leave them for a while. Or it'll gradually subside in the course of use. It's not something to be concerned about, anyway.
Posted : 27/09/2018 7:36 am
